Momenum and differential of momentum
  • Context: Undergrad
  • Thread starter Thread starter Cyrus
    Differential Momentum
The discussion revolves around the concept of momentum and its differential form, particularly focusing on the mathematical treatment of momentum as a product of mass and velocity. Participants explore the implications of differentiating momentum in classical and relativistic contexts, as well as the assumptions underlying these formulations.
  • One participant expresses confusion over the differential form of momentum, noting that the term m * dV seems to be missing from the standard differential momentum equation dp = dm * V.
  • Another participant points out that in classical mechanics, dm is often considered zero, but in special relativity and scenarios involving self-propelled objects, mass can change.
  • A participant suggests that the question about the missing term may only be fully understood within a relativistic framework, where the frame of reference affects the velocity and thus the differential momentum.
  • One participant proposes that the equation dp = dm * V assumes that V is constant with respect to the variable of differentiation, leading to a discussion about the implications of this assumption in one-dimensional cases.
  • Another participant agrees with the previous point, emphasizing that the full formula for momentum must account for changes in velocity and mass in more complex scenarios, particularly in higher dimensions.
Participants do not reach a consensus on the treatment of the differential momentum equation. There are multiple competing views regarding the assumptions necessary for the equation to hold true, particularly concerning the constancy of velocity and the conditions under which mass changes.
Limitations include the dependence on the assumption that velocity is constant with respect to the variable of differentiation and the implications of this assumption in different physical contexts, such as rigid versus non-rigid bodies and one-dimensional versus higher-dimensional scenarios.
Cyrus
This was written on the board this last semester, and I can't seem to figure it out and its been bothering me to no end (mentally).
Momentum is defined as:
p=mv
therefore, if you want to find the differential momentum, it should be, mathematically speaking:
d(p)=d(mv)=dp=dm*V+m*dV
But differetial momentum is always written as:
dp=dm*V
I can't make sense out of what happened to the second term on the right side.
In fluid mechanics we have:
d(\rho VA)=\frac{d \rho}{\rho}+\frac{dV}{V} +\frac{DA}{A}
So d(p) for momentum should follow just the same using the product rule.
It makes sense conceptually, as each particle dm has a velocity V, and if you sum it over the body you get the total momentum, but it seems totally wrong mathematically.
classically, dm=0 in most cases. However, when special relativity is involved, mass does change. Another case where mass changes involves selfpropelled objects (rockets, airplanes) where fuel is burned off changing the mass.
Cyrus is asking what happened to the second term, m * dV. If the differential moment definition is correct as written above, then dp would always be zero according to you. Good question.
I suspect that the answer to your question only makes sense in a relativistic framework.
If our frame of reference is moving with the same acceleration as a given particle, then
m\cdot dV=0 since dV=0.
Then, in this setting,
dp=dm \cdot V+m \cdot dV=dm \cdot V.
However, in this framework, the only useful hint is that momentum affects mass.
Hmm.
Using the equation
dp = dm*V
must implicitly assume that V is constant wrt the variable by which you differentiate.
If that variable is length x, say, then m=m(x) and V=V(x). Then
\frac{dp}{dx} = V\frac{dm}{dx} + m\frac{dV}{dx}.
First, it's important to note immediately that this is only valid in one dimension.
The second term on the right is zero if dV/dx=0, which implies that V is a constant with respect to x. Note that V could actually be a function of some other variable (like time), but our consideration is only with respect to one variable, x. So it appears that dp=dm*V is only valid if you're talking about rigid, non-rotating? bodies in which velocity does not change with respect to the integration variable. The full formula would apply in more general cases.
I could be wrong, tell me what you think.
I think you might have misunderstood my question.
gabee said:
Hmm.
Using the equation
dp = dm*V
I think that you're mostly correct (there is one trivial case which is important to remember).
The body must be rigid (otherwise at some point along the body there might exist a place where dV \neq 0) and must be either non-rotating or rotational velocity is neglected. I suspect that for most cases that the body will be non-rotating.
Your formula is somewhat limiting because it doesn't generalize to higher dimensions, but I think that you have the right idea.
  • · Replies 17 ·
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 67 ·
  • · Replies 27 ·
  • · Replies 0 ·
