MHB Is there a mistake in the satellite's trajectory calculation?
The discussion revolves around simulating the trajectory of a satellite near the L4 position between the Earth and the Moon. The user initially reports that the satellite isn't moving after perturbing its position by 1 km in the x direction and not providing it with initial velocity. The calculations involve gravitational parameters and initial conditions for the simulation. A key issue identified was that the gravitational influence of the Moon was not being accurately represented in the simulation, leading to a lack of movement. The problem was traced to a sign error in the equations governing the satellite's motion. Once corrected, the user successfully plotted the satellite's trajectory over a year, confirming the satellite's movement. The discussion also touches on the importance of plotting over sufficient time to observe the satellite's motion effectively.
Dustinsfl
The L4 position is stable in the Earth Moon and I perturbing a satellite by km in the x direction to see the trajectory over the course of the year. However, the satellite isn't moving. Can anyone see if there is something wrong? I gave the satellite no initial velocity.
Code:
In[2587]:= ClearAll["Global`*"]
me = 5.974*10^(24);
mm = 7.348*10^(22);
G = 6.67259*10^(-20);
re = 6378;
rm = 1737;
r12 = 384400;
In[2594]:= \[Mu] = G*(me + mm);
\[Pi]1 = me/(me + mm);
\[Pi]2 = mm/(me + mm);
M = me + mm;
\[CapitalOmega] = Sqrt[\[Mu]/r12^3];
\[Mu]1 = G*me;
\[Mu]2 = G*mm;
In[2601]:= xl4 = 384400/2 - 4671
yl4 = Sqrt[3]/2*384400 // N
Out[2601]= 187529
Out[2602]= 332900.
In[2612]:= r0 = {xl4+1, yl4, 0}
v0 = {0, 0, 0};
Out[2612]= {187529, 332900., 0}
{187529, 332900.16521473817`, 0}
In[2614]:=
s = NDSolve[{x1''[t] -
      2*\[CapitalOmega]*x2'[t] - \[CapitalOmega]^2*
       x1[t] == -\[Mu]1/(Sqrt[(x1[t] + \[Pi]2*r12)^2 +
            x2[t]^2])^3*(x1[t] + \[Pi]2*
          r12) - \[Mu]2/(Sqrt[(x1[t] - \[Pi]1*r12)^2 +
            x2[t]^2])^3*(x1[t] - \[Pi]1*r12),
    x2''[t] -
      2*\[CapitalOmega]*x1'[t] - \[CapitalOmega]^2*
       x2[t] == -\[Mu]1/(Sqrt[(x1[t] + \[Pi]2*r12)^2 + x2[t]^2])^3*
       x2[t] - \[Mu]2/(Sqrt[(x1[t] - \[Pi]1*r12)^2 + x2[t]^2])^3*
       x2[t],
    x3''[t] == -\[Mu]1/(Sqrt[(x1[t] + \[Pi]2*r12)^2 + x2[t]^2])^3*
       x3[t] - \[Mu]2/(Sqrt[(x1[t] - \[Pi]1*r12)^2 + x2[t]^2])^3*
       x3[t], x1[0] == r0[[1]], x1'[0] == v0[[1]], x2[0] == r0[[2]],
    x2'[0] == v0[[2]], x3[0] == r0[[3]], x3'[0] == v0[[3]]}, {x1, x2,
    x3}, {t, 0, 24*3600*365}];
In[2617]:= ParametricPlot3D[
 Evaluate[{x1[t], x2[t], x3[t]} /. s], {t, 0, 200000},
 PlotStyle -> {Red, Thick}]
I believe the gravity of the moon isn't playing a role in the simulation. Does anyone see a fix for this?
Just curious: what was the problem?
Plot the movement of a satellite at a 1km offset from L4 over the period of 1year. I will put some of these problems in the notes I type about Orbital and link to
So you just hadn't plotted the motion for a long enough time?
Oh that problem. Negative sign when should have been a plus.
