More power series: 2nd-order ODE
Luminous Blob
I felt pretty chuffed after getting the power series solution for a simple first-order ODE (with MathNerd's help) and thought I'd have a go at solving a second-order ODE using the same method. Then I realized I didn't understand it as well as I'd thought...
The differential I'm attempting to find the power series solution for is:
y'' - 2xy' + 4y = 0
My attempt at a solution:
y = \sum_{n=0}^\infty a_nx^n
y\'\; = \sum_{n=1}^\infty na_nx^{n-1}
y&#039;&#039; = \sum_{n=2}^\infty n(n-1)a_nx^{n-2} <br />
substituting into the equation and shifting indices, etc. :
\sum_{n=2}^\infty n(n-1)a_nx^{n-2} -2x\sum_{n=1}^\infty na_nx^{n-1} + 4\sum_{n=0}^\infty a_nx^n = 0
\sum_{n=0}^\infty (n+2)(n+1)a_{n+2}x^{n}-\sum_{n=1}^\infty 2na_nx^{n} + \sum_{n=0}^\infty 4a_nx^n = 0
4a_0 + 2a_2 + \sum_{n=1}^\infty (n+2)(n+1)a_{n+2}x^{n}-\sum_{n=1}^\infty 2na_nx^{n} + \sum_{n=1}^\infty 4a_nx^n = 0
then
4a_0 +2a_2 = 0
and
(n+2)(n+1)a_{n+2} - 2na_n + 4a_n = 0
the recursion relationship is:
a_{n+2} = 2a_n(n-2)/(n+2)(n+1)
Can anyone tell me:
i) if my recursion relationship is correct
and
ii) if so, how on Earth do you get from there to the answer of:
y = c_1(1 - 2x^2) + c_2(x-x^3/3 + ...)
let c(1) =a(0), then you can find a(2) in terms of c(1), a(4) must then be zero by the relation, and hence so must all the other even terms.
now let c(2)=a(1), work out what a(3), a(5) etc are and see if you can prove a general rule about it, things ought to cancel out. alternatively you could look up somewhere how to solve recurrence relations ; they behave like differential equations but aren't taught anywhere near as well in school, if at all.
That's the part I'm having trouble with :)
what do you think the general rule is, have you written down the first few terms and seen why the pattern develops the way it does? there are lots of cancellations, use the relation to write a(n+2) in terms of a(n-2), then a(n-4) then a(n-6)... etc
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
