More theoretical questions about acceleration and velocity
This discussion focuses on the conceptual understanding of velocity and acceleration equations in physics, specifically the relationships defined by constant acceleration. The key equations discussed include v = d/t for velocity, a = Δv/t for acceleration, and the four equations of motion derived from velocity-time graphs: v = u + at, s = ut + 0.5at², s = vt - 0.5at², and v² = u² + 2as. The conversation emphasizes that these equations are definitions rather than proofs, and visualizing them through graphs can enhance comprehension.
  • Understanding of basic physics concepts such as velocity and acceleration
  • Familiarity with the equations of motion for constant acceleration
  • Ability to interpret and analyze velocity-time graphs
  • Knowledge of algebraic manipulation for solving equations
  • Study the derivation of the four equations of motion in detail
  • Learn how to construct and interpret velocity-time graphs
  • Explore real-world applications of constant acceleration equations
  • Practice solving problems involving acceleration and velocity using these equations
Students studying physics, educators teaching motion concepts, and anyone seeking to deepen their understanding of the mathematical relationships between velocity, acceleration, and displacement.
HealthPhysics
This question is from a theory stand point.
I understand the definitions of velocity and acceleration separately. For some reason, I can not conceptualize them in equation form. How do you really know a*t= velocity or d/t=v ? Is there a proof for this or something? I need to understand the reasoning better. The professor for my class is like it just is. Any suggestions on how to make understanding the equations and relationships in physics more concretely in my head? I need more background info then my book is giving to help me to better understand how to derive the constant acceleration equations.
constant acceleration of motion
read text/google search
If a crowd of 60 000 people entered a sports stadium in 40 minutes, then they entered at an average rate of 90 000 per hour.
Is that description OK
Rate of Entry = number of people / time
If a car covers 60 km in 40 minutes, then it was traveling at a rate of 90 km each hour. Rate of covering distance = distance covered / time.
We call THAT rate speed, symbol V, the distance covered is given symbol d and time is given symbol t; so v = d/t
So rather than a proof - it is a definition.
Try this: Prove that the four legged piece of furniture people sit on at a restaurant is a chair. Of course the long legged chair at the bar is actually a stool !
Also if a car increases its speed from 20 km/h to 80 km/h in 40 seconds, it was increasing its speed at the rate of 60 km/h per minute.
We call the rate of increase of speed acceleration (a) so a = Δv/t or Δv = a*t
Now if the initial speed was 0, then the change in speed (Δv) will equal the final speed v so that would look like a*t = v
I understand this already. My question is more about constant acceleration of motion equations. Is there a good way to visualize this?
The equations of motion are mathematical summaries of a simple velocity-time graph.
If a body is accelerating, its velocity-time graph is a sloping, straight line. The gradient of the line is the rate of change of the quantity graphed, defined as acceleration "a".
If the initial velocity is called "u", then that us the intercept on the vertical axis.
After a period of time "t", the velocity will have increased to a final velocity "v".
Thus there is a co-ordinate on the line (t,v).
If you draw such a graph, you add a pair of reference lines: a horizontal line at the initial velocity, and also at the final velocity.
The gradient of the line [rise / run] tells us that the increase in velocity over this time interval is given by a*t.
Thus the final velocity is given by:
v = u + at
The displacement during this time is given by the area under the graph.
Those horizontal lines show that area in 3 ways.
#1 - a lower rectangle plus a triangle [length x width plus 1/2 x base x height]
The rectangle has length t, and width u --> area ut
The triangle has base t, and height a*t so are 0.5 * t * a*t = 0.5at2
using symbol s for displacement we have
s = ut + 0.5at2
#2 - a large rectangle, with a triangle removed from the top left.
The large rectangle has length, t, and width, v, so area vt
as above we get
s = vt - 0.5at2
#3 - before the horizontal lines were drawn, the graph represented a trapezium on its side - the parallel sides are the vertical lines along the vertical axis, and the ordinate t.
The area of a trapezium is given by area = height * (base + top)/2
using our symbols that means
s = t(v+u)/2
That gives us 4 equations of motion - all mathematical summaries of one simple graph.
We can do one more algebraic manipulation using the first and last of them.
s = t(v+u)/2 and v = u + at
The second can be transformed to show t = (v-u)/a
substituting for t in the first we get
s = (v-u)/a * (v+u)/2
multiply both sides by 2a to eliminate the "fractions"
2as = (v-u)(v+u)
The right hand side is the classic "difference of two squares" expression
so
2as = v2 - u2
re-arranging so that there are no minus signs we get the more familiar
v2 = u2 + 2as
  • · Replies 16 ·
