Morin 3.7 -- Block sliding sideways on an inclined plane
In the discussion about Morin 3.7, a user presents an alternative method for solving the problem of sliding sideways on an inclined plane, claiming it yields the correct answer. They derive equations for the motion in both x and y directions, ultimately concluding that the final speed, when v_x approaches 0, is V_f = V/2. However, other participants challenge the validity of this solution, pointing out that substituting v_x = 0 into the derived equations leads to inconsistencies, suggesting that v_y should also equal 0. The conversation emphasizes the importance of careful algebraic manipulation and the potential pitfalls of introducing extraneous solutions when squaring equations. The discussion concludes with a focus on ensuring the physical soundness of the proposed solution.
masteralien
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: In Morin 3.7 sliding sideways on a plane I used a completely different method than he did and got the correct answer is my method right
The problem statement is as follows
I split up the friction force into x and y components derived a diff eq for v_y in terms of v_x then took the limit as v_x goes to 0
My solution was this
$$m\ddot{x} = -\mu mg\cos(\theta) \cos(\varphi)$$
$$\\m\ddot{y}= -mg\sin(\theta)-\mu mg\cos(\theta)\sin(\varphi)$$
$$\\\mu = \tan(\theta)$$
$$\\v_x=\dot{x}$$
$$\\v_y=\dot{y}$$
where $$\varphi$$ is the angle the velocity vector makes
$$\\\dot{v}_x=-g\sin(\theta) \frac{v_x}{\sqrt{v_x^2 + v_y^2}}$$
$$\\\dot{v}_y=-g\sin(\theta)-g\sin(\theta) \frac{v_y}{\sqrt{v_x^2 + v_y^2}}$$
At long times v_x’ will be 0 so we can set final v_x = 0 as setting v_x’=0 means v_x will be 0
I then divided to get
$$\frac{dv_y}{dv_x}=\frac{v_y}{v_x} + \sqrt{1+\left(\frac{v_y}{v_x}\right)^2}$$
I substituted v_y/v_x = u and with some algebra setting the lower bound of v_x as V and upper as v_x to take the limit later and for v_y I took the upper bound as v_y and lower as 0 get
$$\frac{v_x^2}{V}=\sqrt{v_x^2+v_y^2}+v_y$$
$$\frac{v_x^4}{V^2}-\frac{2v_y v_x^2}{V}+v_y^2=v_x^2+v_y^2$$
Then get
$$\frac{v_x^2}{V^2}-\frac{2v_y}{V}=1$$
Finally taking v_x goes to 0
$$v_y = -\frac{V}{2}$$
With the final speed being
$$V_f=\frac{V}{2}$$
I want to know if this solution is correct as this gives the correct answer
This is the book’s solution
Unfortunately, that does not give the right answer if you plug in ##v_x=0##.
Please post the omitted algebra.
Its right below the algebra
The steps are right below. I even checked with a graphing calculator that as v_x approaches 0 v_y approaches -V/2
You wrote
Can you post that?
But if you substitute ##v_x=0## in the equation I quoted you get ##v_y=0##, no?
haruspex said:
You wrote
Can you post that?
No my steps are right below I subtracted v_y and squared both sides then divided by v_x^2 then took the limit. You need to take the limit as it approaches as this for long times its a bit like terminal velocity.
I am asking you to show how you got from
to
I do not see that anywhere.
Squaring introduces extra solutions. Specifically here, you are now solving
$$\frac{v_x^2}{V}=\pm\sqrt{v_x^2+v_y^2}+v_y$$
If we substitute ##v_x=0## in the extra solution that introduces:
$$\frac{v_x^2}{V}=-\sqrt{v_x^2+v_y^2}+v_y$$
we get 0=0, so this spurious solution is the one that, through taking the limit, arrives at ##v_y=V/2##.
$$\frac{v_x^2}{V}=\sqrt{v_x^2+v_y^2}+v_y$$ cannot be right because ##v_x=0## implies ##v_y=0##, whether by taking limits or simply plugging in. It seems likely that it should have been $$\frac{v_x^2}{V}=-\sqrt{v_x^2+v_y^2}+v_y$$.
You can avoid introducing extra solutions by dividing that through by ##v_y##, applying the binomial expansion and taking limits.
Also v_x would never truly reach 0 just get very close and its best to express the solution a bit differently. Also I have plugged in my equation the first into desmos to check and as you decrease v_x it goes to -V/2 but never set v_x=0
$$v_y=v_x\sinh(\ln(\frac{v_x}{V}))$$
Taking x to 0
=$$V x\sinh(\ln(x))$$
=$$V x/2 (x-1/x)= V /2 (x^2-1)$$
=$$-V/2$$ as x goes to 0
to
You can avoid introducing extra solutions by dividing that through by ##v_x##, applying the binomial expansion and taking limits.
Also is my solution physically sound like is the setup logical physically
to
You would have to solve for v_y
I meant divide by ##v_y##, of course.
$$\frac{v_x^2}{Vv_y}=-\sqrt{1+(\frac{v_x}{v_y})^2}+1$$.
$$\approx-\frac 12(\frac{v_x}{v_y})^2$$
$$v_y=-V/2$$
Starting with $$\frac{v_x^2}{V}=+\sqrt{v_x^2+v_y^2}+v_y$$ does not lead to that.
If ## \frac {dv_y}{dv_x} = \frac {v_x}{V} ## is true, from here it can be get that ## v_y = \frac {v_x^2}{2V} - \frac {V}{2} ##. For ## v_x=0 ## ## v_y ## will be ## -\frac {V}{2} ##.
  • · Replies 53 ·
