Is This Physics Calculation Correct for a Decelerating Rotating Ball?
  • Thread starter Thread starter dman_PL
    Circle Motion
The discussion revolves around verifying the physics calculations for a decelerating rotating ball with a moment of inertia of 0.1 kg·m². The ball initially spins at 2π radians per second and slows to 10% of that speed in 2 seconds. Participants emphasize the need to correctly calculate angular deceleration (α) using the formula Δω/Δt and to find the time it takes for the ball to come to rest. There is also a focus on ensuring that the work done on the ball is calculated using the appropriate expressions for rotational kinetic energy. The consensus is that a more algebraic approach should be taken before substituting numerical values.
dman_PL
Can someone check if this is right? The time seems okay, but the work I feel is wrong
A ball with moment of inertia 0.1kg · m2 is rotating on a table, but
friction is slowing it down with constant angular acceleration. The ball is originally spinning at 2π radians per second, but slows down to 10 percent of that value in 2 seconds
1) How long does it take the ball to come to rest (time since it began spinning)
2)How much work is done on the ball to bring it to rest
1)Since angular acceleration is constant, we use ∆ω = α∆t
2)W = ∆K = Kf − Ki = 0 −1/2Iω
1) Since I have the ball spinning at 2π/sec, and it slows down -10% of the original speed in two seconds, so i plug in the information into the equation. so Δw= (-.10)(2π)/2sec which equals -.314159. Which then I can solve for t. New equation: t=Δw/α. So -.314159/-.628318= 5 Sec.
2) (-1/2)(.1kg*m^2)(.628318)^2=-.0197J
friction is slowing it down with constant angular acceleration. The ball is originally spinning at 2π radians per second, but slows down to 10 percent of that value in 2 seconds1) How long does it take the ball to come to rest (time since it began spinning)
Check this. The rotational kinetic energy has dimensions of kg m^2/sec^2. This has dimension of kg m^2/sec.
Better to find the algebraic solution and then plug in numbers.
First, find the angular deceleration α. Then use that to find the time it takes to stop using the correct expression for rotational energy.
AM
AM
So to find α, I am still using Δω/Δt correct?
Correct. You don't have to use energy to work out the time it takes to stop. Just use α = Δω/Δt. What is the change in ω when it stops? Knowing α and Δω you can work out the Δt.
AM
  • · Replies 38 ·
  • · Replies 60 ·
