Motion in One Dimension: Model Rocket
The discussion revolves around a model rocket problem involving upward motion with constant acceleration. The original poster presents a scenario where the rocket reaches a height of 76 meters in 7.2 seconds and seeks to determine the acceleration and speed at that height.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various equations of motion and discuss the calculations for acceleration and speed. There are attempts to clarify the use of time in calculations, with some participants questioning the correctness of initial attempts and suggesting the use of conservation of energy.
Some participants have provided guidance on the equations to use, while others are sharing their calculations and results. There is an ongoing exploration of the second part of the problem, with multiple interpretations and approaches being discussed.
Participants note the initial conditions of the problem, such as the rocket's starting velocity being zero and the time taken to reach the specified height. There are indications of confusion regarding the application of formulas and the interpretation of results.
jojo711
A model rocket accelerates upward from the ground with a constant acceleration, reaching a height of 76 m in 7.2 s.
What is the acceleration (in m/s 2)?
What is the speed (in m/s) at a height of 76 m?
V=Vo+at
X=Xo+volt+1/2at^2
V^2=Vo^2+2at(X-Xo)
I tried 76=1/2a(7.2)--> 76=3.6a-->21.1=a
but it was wrong. Please help me!
My calculator shows 2.93...
Thank You! It said it was right for the acceleration, but could you possibly tell me how you got the answer? And, did you attempt the second part of the problem at all?
7.2 must be squared!
So, I would do 2.93(7.2^2)?
I got 151.8912 as my answer...
That's not right... :(
i was pointing out your mistake for the acceleration.
oh, well. thank you. Do you know how to do the second part of the problem by any chance?
Is the rocket moving vertically upwards?
Yes.
Try to use conservation of energy.
Could you explain what you mean by that? I have no idea what that is.
What kind of energy does it have initially?
What kind of energy does it have at 76m?
you know it takes 7.2 seconds to reach 76m
initially velocity was 0
and you have worked out the acceleration in part 1
looks like you need
v=u+at
or
v^2=u^2+2as
it's not moving, right...?
i don't know. have you used the suvat equations and worked out the value for the speed?
I did it! You guys are sooo helpful! Thank you so so so so so much!
i feel your pain getting to grips with mechanics :)
i am so bad at this stuff, but find it hard to get any help. i post all over the net to no avail :(
same here! this website pretty much saved my life!
  • · Replies 30 ·
