Does Raising My Arm Change the Center of Mass?
Raising an arm shifts the center of mass (CoM) of the body, but this shift does not result in acceleration unless an external force is applied. In a gravitational environment, such as Earth, the ground provides the necessary external force through the normal force. However, in a microgravity environment, like deep space, moving an arm does not change the CoM's position; instead, the body will react by moving in the opposite direction due to Newton's third law of motion. Therefore, the CoM remains fixed in deep space, while the body can adjust around it.
  • Understanding of Newton's laws of motion
  • Basic knowledge of center of mass concepts
  • Familiarity with gravitational and non-gravitational environments
  • Concept of internal vs. external forces
  • Study Newton's third law of motion in detail
  • Explore the concept of center of mass in various gravitational fields
  • Investigate the effects of microgravity on human movement
  • Learn about the dynamics of motion on different surfaces, such as skateboards
Physics students, educators, and anyone interested in understanding the principles of motion and center of mass in both gravitational and microgravity environments.
Physics guy
Let me imagine myself standing on the Earth with my arm in the resting position perpendicular to the ground. Now if I decide to raise my right arm by 90 degrees, now that it is parallel to the ground. I have shifted my center of mass in this process. But the center of mass will not accelerate unless there is an external force on the system. I can only think of internal force that is acting, in this case is the force exerted by my muscles. Is my understanding flawed somewhere?
Physics guy said:
Summary:: Acceleration of center of mass when there is no external force
There is an external force on your feet from the Earth. That's how you are able to walk.
Well this isn't a question of walking or the normal force from the ground. Okay let us suppose that instead of in Earth I am in deep space and I lift my arm. Then in this case what is the external force which shift my center of mass.
Try to do it on a skate board, while holding some weight in your hand (for better effect).
The feet also transmit frictional forces.
Your center of mass will not shift in this case.
So does that mean that I will shift to the left when I raise my right arm.
If you are in deep space and you move your arm, then the rest of your body will move in the opposite direction. Newton's third law.
Yes, the rest of your body will also change orientation a bit.
In deep space, with no external influence, the CoM stays in the same place. You might be able to move your body around it, but it remains fixed.
  • · Replies 24 ·
  • · Replies 30 ·
  • · Replies 25 ·
  • · Replies 22 ·
  • · Replies 131 ·
