roybot
- 2
- 0
- TL;DR Summary
- I could use some help designing a magnetic induction power source to convert kinetic energy to DC power, for use in keeping a GPS unit with GSM SIM card independently powered inside a bicycle frame.
Briefly, the problem; stolen bicycles are notoriously difficult to recover. Designing a GPS tracker to fit on one is challenging, because bicycles rarely have their own available power source. Whatever GPS unit is used must typically have its own battery as its sole source of power, which presents its own set of problems (e.g.; extracting/replacing, remembering to charge it). Stolen bikes also tend to get broken down quickly, so to be effective a tracker would need to be hidden inside the frame itself & out of sight.
I'm trying to design & assemble a GPS tracker meant to be installed inside the seat tube (not the seatpost) of a bicycle frame. If possible, I'd like to design it to use a magnet passing through coils, bouncing up & down across copper coils (like a 'shake' flashlight) to generate enough power over time to keep a small battery charged enough to enable a GPS tracker unit to - if needed - monitor its GSM unit and report its location.
Here's a link to a 'shake flashlight' project - the type of power source I'm talking about.
A GPS tracker unit is easy enough to find. There are tons of them on ebay/amazon. Most common are the types that have a GPS receiver unit with a GSM module featuring a SIM card slot. In all sorts of different ways, they use the GSM to receive signals from the maker's app, and the unit responds with logged GPS location(s). Usually there are settings for how often it logs on its own, or if it only should when asked, etc. Battery life will depend on those settings.
Some trackers promise standby battery life of 4 months or more - but nobody wants to have to dig out a GPS tracker from inside their frame every few months. Chances are they'd forget, and via Murphy's Law it'll get stolen as soon as they do.
I don't know yet how much power it'll take to keep the GSM cell phone unit in standby mode, but all of these units have a 'low power mode'. The GPS location logging can happen very occasionally.
I'll draw a diagram later, but basically I figure the thing will consist of;
If you're curious - yes, I am expecting that I'll need to connect the GPS and the GSM antennae to some point outside of the bike's frame - probably the bottle cage bolts.
- The power source: a magnet inside a cylinder, springs on either end, and copper wire wrapped X times in the middle.
- A 'diode bridge' to convert the AC power generated into DC.
- A capacitor across the +/- after the diode bridge to 'smooth out' the power, some say (?).
- [ some sort of component that takes weak and widely varying voltage and converts it to a steady 5, or 3.7, etc., VDC. ]
- Some lithium battery power bank for the GPS unit, outputs 5V.
- The GPS tracker unit, runs on 5V.
