Motion sensorPositive or negative?
  • Thread starter Thread starter yypsxxxxxx
    Motion Negative
The discussion revolves around the classification of velocity in relation to a motion sensor. When a person moves toward the sensor, their velocity can be considered positive, while moving away can be deemed negative. However, the designation of positive or negative velocity is subjective and depends on the chosen reference point. The key takeaway is that the distinction between the two velocities is what matters, not the labels themselves. Understanding this concept is crucial for analyzing motion in relation to a sensor.
yypsxxxxxx
1 - A person moving toward the motion sensor with constant velocity..
2 - A person moving away from the motion sensor with constant velocity..
For both statement above.. Is the velocity positive or negative?
For the first statement .. i assume that the velocity is positive.. is it right?
For the second .. i assume that the velocity is negative .. is it right?
Really the choice is entirely up to you which one you want to call positive and which you want to call negative, the important part is that the two are different.
