Motor Control Test: Check Setup AC Drive & Motor
Hraabo
TL;DR
Test of AC drive along with motor
Hello
So i was curious to know, what kind of tests you guys would run on a setup, for an AC drive and motor, to see if the controlling works properly?
kind regards
These tests are usually defined by the motor/drive manufacturer. If you have questions about the tests you should contact the manufacturer.
So what you are saying is, that you would perform validation test, and compare them with manufacturer data?
If the validation test is the one described in the manufacturer's manual, yes.
JUst saw this post - IMO - errors are far more often the application of the drive than with the drive itself. In a broader sense - Systems Engineering is the issue, not the component reliability.
Both the main electrical cable (three-phase, line to neutral=230V, line to line =400V, 50Hz) and the water supply line(ppr pipe) are underground, below the earth in the garden, located next to each other, the main electrical power has damaged insulation, bare live line is exposed to a water leak from a broken main potable water line. So fault contact happen before RCD. Could this situation be dangerous, especially if a person is showering at the same time? I am trying to understand whether...
