Motor used for Electric Wine Opener
  • Thread starter Thread starter coooljay
    Electric Motor
The discussion centers on selecting an appropriate electric motor for a DIY electric wine opener. Key requirements include an AC motor that can later accommodate battery power, a torque rating at least double that of standard wine openers, and a low RPM of around 60. The motor must be compact, fitting within a 30mm diameter and 70mm length, and should be moisture-resistant. Recommendations include using universal or DC motors, with a suggestion to consider gear motors for achieving the desired speed.
  • Understanding of electric motor types, specifically AC, DC, and universal motors.
  • Knowledge of gear motors and their applications in reducing RPM.
  • Familiarity with torque specifications and power requirements for kitchen appliances.
  • Basic concepts of moisture resistance in electrical components.
  • Research "gear motor specifications for low RPM applications."
  • Explore "universal motor characteristics and applications in kitchen appliances."
  • Investigate "moisture-resistant casing options for electrical devices."
  • Learn about "torque calculations for electric motors in consumer products."
This discussion is beneficial for DIY enthusiasts, product designers, and engineers focused on developing kitchen appliances, particularly those interested in electric motor selection and application.
coooljay
Hello Friends,
Excuse me if my question is silly, but I am sure you guys can help me out quick.
I am thinking to make an equipment like wine opener. For this purpose I need to chose an electric motor. I am not sure what kind of motor I should look for.
As in the initial phase I can think of a motor running on AC so that I don't have to worry about a transformer. But later I would like to attach a battery as well.
I am not sure to explain how much torque/power I need but say it should be atleast double the power of a wine opener.
It should be reversible. I need this to make a kitchen product. so the motor cannot be expensive.
RPM should be low as around 60rpm but if I can inrease or decrease that will be even better.
It should be small in order to fit inside a cylinder of dia 30mm and length not more than 70mm.
The product can be in contact with moisture or even water. This can be taken care by the casing as well.
Can you suggest which kind of motor will be satisfying aforementioned criterias?
I tried to search on internet but its too much information for me to comprehend and get a start.
Thanks
Jose
Typical kitchen appliances use universal and DC motors. They are inexpensive, easily controlled, bidirectional, and relatively lightweight.
Based on your speed request, you might want to get a gear motor, or you'll have to make your own gearing system since motors typically run much higher speeds.
