Multimeter leads as stimulators?
  • Thread starter Thread starter ttmike42
    Multimeter
The discussion revolves around using a Grass square pulse stimulator for external nerve stimulation, specifically targeting the peroneal nerve. The user is seeking advice on whether multimeter lead sets can be used as electrodes for this procedure, as they are struggling to find appropriately sized electrodes. Concerns are raised about the feasibility of running the leads "backwards" without causing issues. It is suggested to contact Grass technical support for expert guidance on this matter. The inquiry highlights the need for suitable electrode options in biomedical engineering applications.
ttmike42
I have a strange biomedical engineering question...
So I have a Grass square pulse stimulator (similar to the link here http://www.grasstechnologies.com/products/stimulators/stims48.html) which will be run through an isolation unit (the SIU5 http://www.grasstechnologies.com/products/stimulators/stimsiu5psiu6.html).
Now I'm using this voltage stimulator for an external nerve stimulation procedure. We begin the procedure by using this setup to deliver square wave pulses at about 50-70 volts to determine the exact location of the peroneal nerve (runs down the leg just behind the outside of the knee) before we plug microelectrodes into the nerve itself.
The problem is that I cannot find an electrode that seems to be the right size/shape to use for this external stimulation procedure. The ideal shape is that of a multimeter lead set (the stimulator is applied just over the nerve and the other pole is run through a sticky electrode attached at the ankle). So my question is: can I use a plain old multimeter lead set for the stimulator pen attached to my square wave generator and isolation unit? Basically, can we run the lead backwards without any issues?
Any help is appreciated!
I'd be inclined to call the Grass technical support folks to ask this question. They really are the best source for this kind of information.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
