Multivariable Calculus Limit process
12 replies · 7K views · last reply
theno1katzman
Determine whether the limit exists; if it does, what is it?
take the limit as (x,y) -> (0,0) of f(x,y) where f(x,y) = (x^6-y^6)/(x^3-y^3)
What i started doing was approaching along the line y=0 and that would give
lim as (x,0) -> (0,0) x^6/x^3 simplifying to the lim as (x,0) -> (0,0) x^3 which is 0.
Then I approached along the line x=0 and that would give
lim as (0,y) -> (0,0) -y^6/-y^3 simplifying to the lim as (0,y) -> (0,0) y^3 which is 0.
Then i approached along the line y=x
lim as (x,x) -> (0,0) (x^6-x^6)/(x^3-x^3) = 0/0 which is an indeterminate form so I use L'Hospital's rule a few times and continue to get 0/0. This rational function is the same as saying (x-x)/(x-x).
I conclude that the limit does not exist because it can not be evaluated any further. Am i correct? Is there something else I shoudl be doing? This homework problem is due March 22.
Thank you for your help.
Welcome to PF!
Hi theno1katzman! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
hmm … I've a nasty feeling that the domain of the function isn't supposed to include the line x = y, in which case you can't approach along that line.
Try approaching along a curve on which f(x,y) is constant. :wink:
Thanks Tim, when I tried approaching (0,0) along the curve y=e^x I will get
limit of (x,e^x)->(0,0) of (x^6-e^(6 x))/(x^3-e^(3 x)) = 1
This is a different answer for the limit above which was 0, therefore the limit of the original function as (x,y) approaches (0,0) does not exist.
theno1katzman said:
Thanks Tim, when I tried approaching (0,0) along the curve y=e^x …
(please use the X2 tag just above the Reply box :wink:)
erm :redface: … noooo …
y = ex doesn't get anywhere near (0,0), does it? :wink:
Try again, to find a curve on which f(x,y) is constant (you may have to solve a quadratic). :smile:
Let me know if this is correct. If I approached (0,0) along the path y=x n where n is any positive integer for example y=x2 then after factoring I would get
lim (x,x2)-> (0,0) x3(x2-x+1)/(x2+x+1) = 0/1 = 0.
Therefore the limit exists and is 0.
I didn't follow that … for y = x2, it would be x3(1 - x6)/(1 - x3), which does --> 0.
But that doesn't prove it for all paths, does it?
Try my previous hint, to find a curve on which f(x,y) is constant.
[tex]y = x^6 + c[/tex] [tex]lim (x,y) -> (0,0) f(x,y)[/tex]
Did you notice that the numerator is a difference of squares ?
Ahh yes I will simplify this to [tex]x^3+y^3[/tex] and work the problem again
So the limit = ?
The polar coordinates works also :)
limit would be 0 if I use polar coordinates, question, would polar coordinates prove the limit exists for all paths?
Yes.
There is a big difference in solving multivariable limits between the 2-path rule (which is y=mx .. etc) and the polar coordinates method.
2-path rule proves only that the limit D.N.E and does not prove the existence of the limit.
Polar coordinates method proves both cases.
Thank you, I wish my professor would have clarified that in class.
