Doc
- 47
- 4
- TL;DR Summary
- Stress minimization in design of spring clip
Hi all,
(Please move to general or mechanical engineering sub-forum if more appropriate over there. I put this here as it is essentially a mathematics problem.)
Broken into sections:
- problem categorization (what type of problem I think I have),
- the question,
- specifics (description of the design task and all variables),
- solution attempt.
Problem categorization
I have a design task that I believe to be a multivariable constrained optimization problem.
Question
I have a stress induced in a piece of glass by a spring clip σG(D,w), how do I minimize this stress in the context of multivariable optimization? Or is there a more appropriate way to solve this problem?
Specifics
I need to design a spring clip (three identical clips will be used) that will retain a piece of glass in a mount, Figure 1.
Figure 1, spring clip shown retaining cut-away section of glass.
The clip needs to retain the glass with a set preload, F. The clip preload will induce a compressive stress in the glass, σg, and this should be minimised so as not not damage the glass. Figure 2 shows a diagram of the spring clip with its associated dimensions, ignore t and L for now.
Figure 2.
The stress induced in the glass is given by:
\sigma_G = 0.798 \sqrt { \frac {K_1 \frac {F} {w} } {K_2} }
Where w is the width of the spring clip and:
K_1 = \frac {1} {D}
And:
K_2 = \left[ \frac {(1- \nu^2_G)} {E_G} \right] + \left[ \frac {(1- \nu^2_M)} {E_M} \right]
ν is the material Poissons ratio and E is the material Young's modulus. The subscripts G and M refer to glass and metal, respectively.
Therefore the stress in the glass, σg, is a function of the diameter, D, of the rounded end of the clip and the width of the clip: the rest of the components may be considered constants. So I have:
\sigma_G (D,w)
Solution attempt
The procedure, as I understand it, is to:
1. reduce the equation or quantity that I want to optimize (minimize in this case) and reduce it down to a single variable,
2. differentiate,
3. set equal to 0,
4. solve for the variable.
In order to achieve step 1 I will simply say that, for practicality in using the clip after manufacture, D > w. To keep things simple I'll say that D = 2w.
Recall the equation for stress:
\sigma_G = 0.798 \sqrt { \frac { \frac {1} {D} \frac {F} {w} } {K_2} }
I can then substitute D and rewrite the stress equation:
\sigma_G = 0.798 \sqrt { \frac { \frac {1} {2w} \frac {F} {w} } {K_2} }
Combining terms and simplifying gives:
\sigma_G = 0.798 \sqrt { { \frac {F} {2w^2 K_2} } }
Taking the constants out of the root gives:
\sigma_G = 0.798 \sqrt{ \frac {F} {2w^2} } (w^-1)
Taking the derivative gives:
\sigma_G = -0.798 \sqrt{ \frac {F} {2w^2} } (w^-2)
I got to here and then started getting from what I could tell to be nonsensical answers.
Would be much appreciated if somebody could let me know where I'm going wrong. Apologies, it's been sometime since I last used this stuff.
Regards,
Doc
- the question,
- solution attempt.
Question
Specifics
Figure 2.
K_1 = \frac {1} {D}
And:
\sigma_G (D,w)
Solution attempt
2. differentiate,
3. set equal to 0,
Regards,
Doc
