My weight increases, but does the scale say zero?
When traveling near the speed of light, an object's mass increases, but its weight, as measured by a scale, would read zero in the absence of gravitational pull. In free space or during free fall, both the scale and the individual move with the same velocity, resulting in a "weightless" condition. Special relativity distinguishes between rest mass and relativistic mass, where an observer at rest relative to the object measures its rest mass, while an external observer measures an increased mass. Therefore, scales cannot accurately measure weight in a zero-gravity environment.
  • Understanding of special relativity principles
  • Knowledge of mass vs. weight concepts
  • Familiarity with gravitational effects in space
  • Basic comprehension of frames of reference in physics
  • Study the implications of Einstein's theory of special relativity
  • Explore the concept of weightlessness in free fall and orbital mechanics
  • Investigate the differences between rest mass and relativistic mass
  • Learn about the effects of gravity on scales and measurement in space
Physicists, students of physics, and anyone interested in the effects of relativity and gravity on mass and weight measurements in space.
javas1
This is a general question, not requiring an equation.
If I travel near the speed of light, I know my mass will increase. I am assuming my weight will increase, but since there is little gravitational pull, since I am not near any large objects, then my scale would say near-zero, if I stepped on a scale?
Thank you.
Thank you.
If there is no gravitation, and you are not in a spinning space craft, you can not step on the scale, but only keep it next to your feet, so as not let it fly away. You can not use scales in free space to measure mass.
You do not feel that your mass is more than normal when you travel with uniform velocity, as your velocity is zero in your own frame of reference.
Neither would any other scales, traveling with you, measure increase of your mass. Your mass is big for an observer who sees you traveling with speed near c.
ehild
ehild
Thank you. That helps. Hypothetically speaking, if I stepped on a scale, then the scale would read zero, because there is no gravitational pull while traveling in a ship near the speed of light?
Gravitational pull and traveling near the speed of light are different things. If you travel in free space or just orbit around a planet or you are in a vehicle in state of free fall, you are "weightless" as both the scale and you move with the same velocity and acceleration. No need to travel near the speed of light.
Special relativity makes distinction of the mass measured from different frames of reference. If the observer measures the mass of an object that travels with some speed relative to him, he would measure the mass bigger than the "rest" mass. An observer traveling together with the object would measure the rest mass. If you travel alone in free space, far away from anything you even do not know your speed.
ehild
Have you seen videos of astronauts in Earth orbit? Imagine one of them trying to step on a scale.
That is what I cannot reconcile with. The astronauts in the space shuttle, when orbiting earth, would not be able to step on a scale.
That makes perfect sense.
Thank you again for your time.
  • · Replies 17 ·
  • · Replies 24 ·
