Name of a switch that alternates between two states.
  • Thread starter Thread starter balsaboom
    States Switch
The discussion centers on identifying a switch that alternates between two states when depressed, exemplified by a flashlight that turns on and off with a click. This type of switch is referred to as a SPST (Single Pole Single Throw) push-on push-off push button switch, also known as a latching pushbutton switch. Users are directed to resources like Digikey for purchasing options, highlighting the importance of selecting the correct ratings and avoiding bulk orders. The term "reciprocating" is mentioned as a possible descriptor for this type of switch. Overall, the conversation provides clarity on the terminology and purchasing considerations for these switches.
balsaboom
I'm wondering what the name of a switch that alternates between two states only when depressed. An example would be a flashlight, where if you click it once, it turns on, and if you click it off, it turns off (no need to hold down the button to get a continuous light).
thanks!
i think I've seen the adjective "reciprocating" used for that kind of switch.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
