What are Different Types of Vector Normalization?
  • Thread starter Thread starter juliette sekx
The discussion focuses on the need to specify types of vector normalization, particularly distinguishing between max-normalization and Euclidean normalization. One participant seeks terminology to succinctly describe the process of dividing each element by the largest element in the vector. It is clarified that simply stating normalization to a range of 0 to 1 does not inherently imply max-normalization. Additionally, the importance of addressing negative components in normalization is highlighted, as failing to do so could compromise the norm property. Clear terminology is essential for effective communication in mathematical contexts.
juliette sekx
I want to write that I'm normalizing a vector, but I need to specify what TYPE of normalization I'm doing.
I want to say that I'm dividing each element by the largest element in the vector, rather than something else like dividing all elements by the Euclidean length of the vector or something like that.
Is there a word for these two types of normalization, so that I don't need to explain what I'm doing in words ?? Like for ex. "max-normalization" and "Euclidean Normalization" ??
If I said that I'm normalizing the elements to lie between 0 and 1, would it be obvious that I'm dividing each element by the largest element in the vector ??
THank you.
Mathematics news on Phys.org
So you use the maximum norm ...
... and the Euclidean norm.
No. This would not be the only possibility.
THank you.
Also you have to specify how you deal with negative components. You might lose the norm property if you don't apply absolute values first.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
