Need formula to relate distance to arcsec in the sky
  • Thread starter Thread starter leonne
    Formula Sky
The discussion focuses on calculating the time it takes for a supernova explosion to appear as one arcsecond from Earth, specifically at a distance of 50 kiloparsecs. Participants suggest using the formula D=H/2tan(a) to relate the diameter of the explosion to the observed angle, while also emphasizing the importance of understanding small angle approximations where θ ≈ sin(θ) ≈ tan(θ). The shockwave from the supernova is noted to propagate at approximately the speed of light, which is crucial for determining visibility and expansion rates.
  • Understanding of angular measurements in astronomy, specifically arcseconds.
  • Familiarity with the concept of kiloparsecs as a unit of distance.
  • Basic knowledge of supernova mechanics and expansion rates.
  • Geometry principles related to small angles and trigonometric functions.
  • Research the formula for angular diameter distance in cosmology.
  • Learn about the expansion rates of supernova debris and their implications.
  • Explore the relationship between distance, size, and visibility in astronomical observations.
  • Investigate the physics of supernova explosions and their shockwave propagation.
Astronomy students, astrophysicists, and anyone interested in the dynamics of supernovae and their observational characteristics.
leonne
I need to find how long it will take a supernova explosion to be a size of one arc sec here on earth, the distance to this explosion is 50 kilparsec
Any clue on what the formula is?
thanks
Wiki defines the kiloparsec at http://en.wikipedia.org/wiki/Parsec so you can get the circumference at 50 kpc using Pi*d. Then divide by 360 to get degrees, 60 to get minutes, and 60 again to get seconds.
hmm, don't think that will help me I need to find how big the explosion needs to be to see 1 arc sec. With the radius, than i can calculate the time. I found this formula D=H/2tan(a) , but don't think it will work. either hmm. Well if I solve for H would that be the true diameter of the explosion?
Well thanks for the help
Have you tried drawing a diagram to see what the geometry of the situation is?
Things to keep in mind for very small angles: θ ≈ sin(θ) ≈ tan(θ).
You're looking for the time it takes "a supernova explosion to be a size of one arc sec [as seen] here on earth". What were you planning on using for the expansion rate of the supernova debris?
hey,
well i remembered using a formula last semester to find something similar, but forgot what the formula was. I found what the velocity was in part 1.
leonne said:
hey,
The shockwave of a supernova propagates at approximately the speed of light. I would suspect that's visible.
well we where told that ...ejected mass of 20 solar mass.
  • · Replies 19 ·
  • · Replies 23 ·
