Engineering Need help about the magnetic field near an infinite current sheet
The discussion focuses on solving a problem related to the magnetic field near an infinite current sheet, specifically point (c) of the question. The original poster calculated the magnetic field strength using a formula but arrived at an incorrect answer. Participants suggest using Ampere's Law and emphasize the importance of defining the correct path for the calculations. Clarifications are made regarding the use of dot versus cross products in Ampere's Law, and the poster is guided to consider the contributions from multiple loops to arrive at the correct result. The conversation highlights the need for a clear understanding of the application of Ampere's Law in this context.
e0ne199
hello everyone, i have a question about magnetic field from infinite current sheet...
the equation will be related with the application of Ampere's Law on current sheet
here is the question, don't mind about point (a) and (b) because i have solved them already...the main problem is the question on point (c) :
so far, what i have done is : H = 2.7*0.1-(1.4*0.15+1.3*0.25) = -0.265 az A/m which is the wrong answer compared to the solution provided from the question...any help is really appreciated, thanks before
e0ne199 said:
what i have done is
I don't see the y-coordinate of ##P## in your version ?
Use Ampere's law ##\oint \vec H d \vec l = I## twice. Use a rectangular path (which have to be in the plane perpendicular to the current direction). The first one would have to include pieces of all three current planes; this would give you the field on both sides of the stack of planes. The second one would have to go through your test point P.
sorry for the late response, but do you know how to apply your solution to my problem? probably i still have a little understanding for this kind of question...please help
could you please point out which is wrong on my current answer?
hallo, anyone?
Did you read the replies ?
e0ne199 said:
hallo, anyone?
Instant service required after two weeks of silence? Still nice to hear back from you :wink:
Yes, Ampere's law. As @Henryk wrote. It involves a path (maybe even several paths). Where is your path ? Is P on that path ?
i am sorry, i really don't understand about your clue...i did try to find another example for a whole week after posting that question here... the possible way i could think of is like this :
(2.7-1.4) X ay = 1.3 az A/m but i am not sure if the way i get the answer is right or not...
But do you understand what I am asking ? Ampere <--> path . Where is your path ?
What is X ? What are you doing here and how is it related to Ampere's law ?
ok, here is the path, P is the green one, and pink line is the path.
about this
i was doing a calculation with cross product, but i am not sure if this is the right way to do, since
H=K X an
so please tell me if i am doing it wrong or not
oops, sorry, I have a symbol missing in Ampere's law, it should be ##\oint \vec H \cdot \vec l = I##, i.e. dot product, not cross product and I is the total current enclosed by the loop with the direction given by the right hand rule.
Now, you notice that you can move vertical vectors left or right (i.e. changing the length of the horizontal vectors, portions of the path) and as long as they don't cross current planes, the enclosed current remains the same. This tells you ##H_y = 0##. Similarily, the loop can be moved up or down and, since the current density is constant, the ##H_z = const##
Now, consider the two loops, ABCD and FBCE and you should get the correct answer.
Likes BvU
@e0ne199 : Isn't it wonderful what a clear picture can do !
based on the diagram, the result is like this :
##H_z * l = K * l##
##H_z =##(loop ABCD)+(loop FBCE) = (2.7-1.4-1.3) + (-1.3) = -1.3 ##a_z## A/m
is that result correct?
umm.. hello, anyone?
