Need help finding coefficient of kinetic friction
To find the coefficient of kinetic friction for a 40.0 kg crate pushed with a 150 N force at constant speed, the normal force was calculated as 392 N. Since the crate moves at constant speed, the frictional force equals the applied force of 150 N. The coefficient of kinetic friction is then determined using the formula fK = coefficient of kinetic friction × N, leading to a value of approximately 0.38. This calculation confirms that the frictional force balances the applied force, resulting in no net acceleration. The discussion concludes with the correct coefficient value.
zinniagirl
A horizontal force of 150 N is used to push a 40.0 kg packing crate a distance of 6.00 m on a rough horizontal surface. If the crate moves at constant speed, find the coefficient of kinetic friction between the crate and the surface.
fK= coeff. of kin. friction X N
Fy= -mgy + normal force
I started by using Fy= -mgy + N to be 0= -40 (9.8) (cos 0) + N and found N be 392. But now I'm not sure where to go from here to find the coefficient of kinetic friction. Can anyone help?
Constant speed means the resultant force is zero...so what is the value of the frictional force?
150 N. So the coefficient of kinetic friction would then be .38, correct?
Yes that should be correct.
Thanks!
