Need help finding the volume of a Angle Food Cake pan using integration.
The discussion focuses on calculating the volume of an Angel Food Cake pan using integration techniques. The pan has a height of 10 cm, a bottom radius of 10.5 cm, and a top radius of 14.25 cm, while the central hole has a height of 10 cm, a bottom radius of 3 cm, and a top radius of 2 cm. Participants suggest using the frustum of a cone formula to find the volumes directly, but also provide a method for setting up integration around the y-axis if required. The key steps involve establishing a coordinate system, finding the equation of the line representing the pan's side, and integrating to find the volumes of both the pan and the hole.
  • Understanding of frustum of a cone volume calculation
  • Basic knowledge of integration techniques in calculus
  • Ability to set up a coordinate system for geometric shapes
  • Familiarity with finding equations of lines in a Cartesian plane
  • Learn how to calculate the volume of a frustum of a cone using the formula
  • Study integration techniques for finding volumes of solids of revolution
  • Explore coordinate system setups for geometric integration problems
  • Practice finding equations of lines given two points in a Cartesian plane
Students studying calculus, particularly those focusing on integration and volume calculations, as well as educators teaching geometric applications of calculus.
alexf322
For class I had to measure an angle food cake pan using integration. The pan itself had a circular hole in the middle of it. So I figured I would take find the volume of the Large pan and then subtract the volume of the Small circular hole in the middle.
As far as integration goes, I am kind of lost. I measured the pan and found the height to be 10cm, bottom radius to be 10.5cm and the top radius to be 14.25cm. The hole in the middle of the pan has a height of 10cm, bottom radius of 3cm and a top radius of 2cm. I figured I would use the integration of a frustum of a cone around the y-axis but I am having a big trouble setting it up.
Any help would be appreciated.
I think you mean angel food cake. Angle food cakes can get stuck in the throat if the angles are too acute.:-p
hah yeah I meant Angel Food Cake*
If you are allowed to use the "frustrum of a cone" formula, you don't need to integrate at all. Find the volume of the frustrum of a cone ignoring the hole, find the volume of the hole, and subtract.
If you cannot use the formula but must integrate, note that if we set up a coordinate system having the origin in the center of the pan, the positive y-axis up and the positive x-axis to the right with units in cm. In that coordinate system, one side of the pan, on the right, passes through the points (10.5, 0) and (14.25, 10). Find the equation of that line, y= ax+ b. Then the radius of a disk, at height y, is x= (y- b)/a. Find the area of such a disk and integrate that area, with respect to y, from y= 0 to y= 10. Do the same to find the volume of the hole, and subtract.
Also if I flipped the frustum over, so that the height of the frustum is laying on the x-axis, I can just integrate it over the x-axis right?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
