Solving Ohm's Law Problem: Understanding Potential Difference in a Circuit"
  • Thread starter Thread starter maxpayne_lhp
    Law Ohm's law
The forum discussion centers on solving a circuit problem using Ohm's Law, specifically calculating the potential difference \( U_{MN} \) between two points in a circuit with given resistances and an electromotive force (emf) of 48V. The resistances are defined as \( R_1 = 2 \Omega \), \( R_2 = 8 \Omega \), \( R_3 = 6 \Omega \), and \( R_4 = 16 \Omega \). The conclusion reached is that \( U_{MN} = 4V \), derived from the equivalent resistance calculations and current through the resistors. The discussion also clarifies that there is no potential difference between points M and N due to the absence of resistance between them.
  • Understanding of Ohm's Law and circuit analysis
  • Familiarity with series and parallel resistor combinations
  • Basic knowledge of electromotive force (emf) in circuits
  • Proficiency in using LaTeX for mathematical expressions
  • Study the calculation of equivalent resistance in complex circuits
  • Learn how to apply Kirchhoff's laws in circuit analysis
  • Explore the use of LaTeX for formatting equations and circuit diagrams
  • Investigate the impact of internal resistance on circuit performance
This discussion is beneficial for physics students, electrical engineering students, and anyone interested in understanding circuit analysis and the application of Ohm's Law in practical scenarios.
maxpayne_lhp
Well, I'm quite idle in Lunar New year's holidays so I decide to do some exercises on Physics, I got stuck when solving the problem, then I tried with the suggestion on my textbook, but still, I don't understand the problem, please help me out! btw, sorry, something has gotten on LaTex or I'm too bad at it, so I just place the raw syntax, sorry!
Well, we have the figure:
http://img.photobucket.com/albums/v649/maxpayne_lhp2/5.jpg
And also, we have:
\emf=48V, r(Internam resistance)=0\omega
R_1=2\onega
R_2=8\onega\]
R_3=6\onega
R_4=16\onega
Well, they told me to find out the value of U_{MN} (Well, in my native scientific system taugh in school,U_{MN}stands for the potential diferece between M and N.
Well, obviously, I found that
U_{MN} = U_{MA}+U_{AN}
=U_{AN}-U_{AM}
Then, I tended to account for the Intensity of the current thru AB via the formula:
I=\frac{\emf}{R_{AB}}
Then, I found out that I=8 (A)
But soon, I saw something wrong and looked up in the suggestion corner, they told me:
As r=0. we have
U_{MN}=\emf. Let the current flows thru AMB and ANB from A to B, then:
U_{AN}=\frac{U_{AB}}{R_2+R_4} . R_2 = \frac{\emf}{R_2+R_4} . R_2= 16V
Do the same thing with U_{AM}
Though, I don't really understand what they mean, so please help me out! What did I do wrong?
Thanks for your time and help!
There is no resistance between M and N so there is no potential difference. M and N are at the same potential.
To find the potential difference across R1 and R2, work out resistance for R1 and R2 in parallel: 1/R_{1,2}=1/R_1 + 1/R_2 and for R3 and R4 in parallel: 1/R_{3,4}=1/R_3 + 1/R_4. Add R_{total}=R_{1,2}+R_{3,4}. Then work out the total current using I = V/R_{total}. That will allow you to work out the potential from A to M and from M to B.
AM
Ohh, sorry, I'm so clumsy, I didn't mean to draw a straight line connecting M and N, there was nothing connecting them at all. yes, they meant to cross the resistances.
And that's helped. Thanks!
BTW, I got difficulty when I need to go down for the next line, what's the syntax in LaTex for it? If you don't have time, please send me a link so that I can refer. Thanks a lot!
Then the currents I_13 thru R_1 & R_3 and I_24 thru R_2 & R_4 are given by:
:(1): \ \ \ \ I_{13} = \frac {E} {R_1 + R_3}
:(2): \ \ \ \ I_{24} = \frac {E} {R_2 + R_4}
from which you can determine all required voltage drops. The overall equivalent resistance R will then be:
:(3): \ \ \ \ R = \frac {E} {I_{13} + I_{24}} = \frac {1} { \frac {1} {R_1 + R_3} + \frac {1} {R_2 + R_4} }
Oh thanks, I got it, it's U_{MN}=4V
Thanks a lot!
Excuse me, still, I don't know what
for? Please explain for me.
Thanks!
btw, if we figure the another way, as thru R3 and R4, is it the same?
Thanks
The equivalent resistance R is the value of a SINGLE resistor that can REPLACE ALL the resistors R_1, R_2, R_3, and R_4 between your battery. In other words, this resistor R will draw the same current that ALL your other resistors draw TOGETHER when connected to a battery. It's useful to know R in terms of the OVERALL operation of ALL the resistors. However, you still need to use the individual resistor values to determine voltage drops between the individual resistors inside your circuit -- just like you were doing.
Well, okay, Thanks!
Thanks for all of your time and help!
10K
9K
  • · Replies 22 ·
