Need help to identify the parts needed
  • Thread starter Thread starter novinox
    parts
The discussion revolves around the construction of a tortilla pressing device, focusing on the necessary parts, specifications for a pneumatic cylinder, and safety considerations. Participants explore various design aspects, including automation, size requirements, and operational features.
  • Experimental/applied
  • One participant seeks advice on the parts needed for a tortilla pressing device and the specifications for a pneumatic cylinder.
  • Another participant suggests the need for a 120 psi air compressor and a control system for solenoid valves, along with hotplates for cooking, although the original poster later clarifies that hotplates are not needed.
  • A safety feature involving two buttons is proposed to prevent accidental operation, emphasizing the importance of safety in machinery design.
  • Discussion on the size of the pneumatic cylinder and the area of the piston in relation to the size of the tortilla disks is raised, with a request for specific recommendations on parts.
  • One participant questions the necessity of a pneumatic press if heating is not involved, suggesting a hand-operated press as a simpler alternative.
  • The original poster outlines a more complex design involving a conveyor system and automation, indicating a shift in project scope.
  • Another participant emphasizes the need for additional information, such as the time per tortilla and food safety requirements, to provide more accurate assistance.
  • One participant presents a detailed calculation for the pneumatic cylinder size based on the desired tortilla size and pressure requirements, including assumptions about air pressure and force needed.
Participants express differing views on the necessity and complexity of the pneumatic press versus simpler alternatives. There is no consensus on the specific parts needed or the design approach, as multiple competing ideas and requirements are presented throughout the discussion.
Participants highlight the need for further details regarding operational timing, safety regulations, and food safety standards, which are essential for accurately advising on the project. The discussion also reflects varying levels of experience among participants, influencing the complexity of proposed solutions.
Individuals interested in DIY projects related to food processing machinery, particularly those exploring pneumatic systems and automation in culinary applications, may find this discussion beneficial.
novinox
Hi, I am trying to build a tortilla pressing device.
If possible could anyone let me know what are the parts i need to get and also the size/power of the pneumatic cylinder should be. Thank you.
Welcome to PF.
That is a big project you are taking on. How automatic do you need it to be?
You will need a 120 psi air compressor to provide air for the pneumatic cylinder, and a system capable of controlling the solenoid valves while operating the machine through the programmed cycle. You will also need a couple of 1 kW hotplates, with thermostats to regulate the temperature.
There are more details here about a similar machine.
http://www.gtfoodmachine.com/product/gt-lm30q-pneumatic-type-tortilla-press-machine-900pcsh/
Thank you for your assistance. Sorry that I forgot about the hot plate part which i don't need.
My goal is to have the operator press a button and have the pneumatic air cylinder press the dough ball and then retract afterwards.
As i am very new to this could you please recommend a pneumatic air cylinder size and other related parts and accessories from the link below. Thanks you.[Mentor Note -- a possible spam link has been deleted from this post]
You better make that TWO buttons to press, with logic so they must both be released before the next cycle can start.
That way a hand does not accidentally get formed into a tortilla shape!
The "must both be released" requirement is so one button can not be taped down to start the next cycle by pushing just the other button.
Here in the US, that, or a similarly effective safety feature, has been required on presses for at least 40 years. Too many people lost hands!:cry:
Cheers,
Tom
The area of the piston in the pneumatic cylinder will be proportional to the area of the disks you use. That assumes the dough has fixed characteristics.
What diameter disks will you use ?
I'm looking to make 7inch tortilla with 2-5mm thickness, so i want to have an 8inch disc.
Also can you advice me on what parts i need to get to make such a machine so that i can start making the frame and assemble everything and fix what ever errors i might have made. ( like the size/strength of pneumatic cylinder, air filter type, type of switch...).
If you do not need the plates to be heated, then why not use a hand operated press that is available for about US $30. Search eBay or Amazon for Tortilla Press.
https://www.ebay.com.au/itm/353897072952?
You will need to cook the tortillas at the rate you press them, so you have more than a minute to operate the press between cooking and stacking the previous item. A hand press has about 50 times lever advantage, so it should not be difficult.
I cannot see any reason for having a pneumatic press, with all the ancillary controls necessary to make it safe, if it is not also cooking the product.
Have I failed to understand your requirements and reasoning ?
I wanted to assemble everything on a frame with a conveyor type belt with motorized rollers and have the dough balls placed between two sheets of thin plastic and have it move forward after each press. Each pressed tortilla would be covered in plastic for freezing. I saw some machines online and wanted to make one myself so i thought someone might tell me the suitable parts needed for the pneumatics ,anyways thank you.
Post #1 does not have enough information to properly help you:
Post #3 has a little more information:
And a little more in Post #6:
Post #8 changes the scope of your project. Now it's a complete machine:
But we still do not have enough information to help you. We need to know more in order to start helping you. For a start:
1) What is the time per tortilla? This is needed to size pneumatic components and the air compressor.
2) We can help break down the time per tortilla into the time to feed the next tortilla, press it, and raise the presser to make room for the following tortilla.
3) What is the force to compress the tortilla in the time calculated in Step 2? You need to measure this before we can help you size an air cylinder.
4) You need to know about food safety requirements in your country because those requirements affect what components you are allowed to use in a food production line.
I am assuming that you have already figured out how to make tortilla dough, how to make exact size balls of tortilla dough, feed those balls onto your conveyor, control the conveyor, and stack the pressed tortillas.
I actually wanted to make this machine myself, but i don't think i can finish this before Ramadan time so for for now I've decided to purchase a cheap doughball pressing machine from China.
I am also very thankful to Baluncore, Tom.G and jrmichler for taking your time to respond and also i do apologize for not providing enough details before posting my request.
Hopefully before the end of April i will have finished the body and motorized conveyor for the machine and at that time i hope everyone can assist in designing and automation of the pneumatic press and conveyor.
Once again thank you all.
Note: The John Steinbeck novel “Tortilla Flat” went to press in 1935.
If there is no cooking, then there is no need for the circular plates on the production line. A simple roller based system could be used. That would eliminate the handling problems of loading the lump of dough, and removing the pressed tortilla. That also eliminates the compressed air, the pneumatic cylinder, and most of the cyclic control.
We can try to reverse engineer from a picture of a unit with a 300 mm plate.
Plate outer diam = 224 - 27 = 197 pixels. That is 300 / 197 = 1.523 mm / pixel.
Cylinder diam = 162 - 84 = 78 px; 78 * 1.523 = 118.8 mm; Probably 4 inch bore.
Rod diam = 138 - 116 = 22 px; 22* 1.523=33.5 mm. Probably 1.25 inch diam rod.
Stroke = 215 - 141 = 74 px; 74 * 1.523 = 112.7 mm. Probably 4.5 inch stroke.
Scale by area of circle. Area = Pi * r^2
Area of 280 mm (11") tortilla = Pi * ( 11” / 2)^2 = 95.0 inch²
Area of piston in cylinder = Pi * ( 4” / 2)^2 = 12.5 inch²
Assume air pressure is 100 psi, then force = 12.5 * 100 = 1250 lbs on rod.
That works out at 1250 / 96 = 13.0 psi on the tortilla dough.
To press an 8” diameter, with area = Pi * (8 / 2)^2 = 50. inch²
You will need to press 50 * 13 = 650 pounds.
Using the same 100 psi air you need a cylinder area of 6.5 inches.
Sqrt( 6.5” / pi ) = 1.43” radius = 3” diameter pneumatic cylinder.
A 1 inch rod would be sufficient.
The stroke would not change, it would remain about 4½ inch stroke.
:-p
  • · Replies 18 ·
