Need Help Understanding K_a & K_b for Bicarbonate Ion
  • Thread starter Thread starter kirsten_2009
    Ion
K_a and K_b are the acid and base dissociation constants, which measure the strength of acids and bases in solution. They quantify how well an acid or base ionizes in water, with strong acids like HCl fully ionizing and weak acids like HF partially ionizing. The equilibrium constant for a reaction is calculated using the concentrations of products and reactants at equilibrium. To find K_a and K_b for the bicarbonate ion, one must understand its dissociation reactions in water. Additional resources, such as Wikipedia, can provide further clarification on these concepts.
kirsten_2009
Hi everyone, I need help understanding something. My assignment is talking about the dissociation of CaCl2 and NaHC03- in water and heats of solution etc and says: "Write out the K_a and K_b for the bicarbonate ion with chemical equations". Problem is though that I don't even know what K_a and K_b is...I've never seen this in my life, my high school teacher must of missed this completely and now they're asking this of me in University! So, if anyone could explain to me what this is and how I go about finding a solution I would MOST SINCERELY appreciate it! Help please! :)
Ka and Kb are called the acid and base dissociation constants. They are basically a way to measure how strong a particular acid or base is.
Im assuming that you have learned about chemical equilibrium? If you have the following reaction:
A+B \rightarrow C+D
Then the equilibrium constant is given by:
K=\frac{[D][C]}{[A]<b>}</b>
This number will represent how far the reaction proceeds in the forward direction before reaching chemical equilibrium.
If you recall from your study of acids and bases, the strenght of an acid is how well it ionizes in a solution. For example, HCl in water will almost fully ionize into H+ and Cl- ions and is therefore a strong acid. However, HF is a weak acid and will only partially ionize. To quantify the extent to which it does actually ionize (i.e. the strength of the acid), the equilibrium constant of HF ionizing is used, which is called Ka.
The same applies for a base. So to summarize, Ka and Kb are really just equilibrium constants that are given a special name when applied to acid/base reactions.
For more info, have a look at http://en.wikipedia.org/wiki/Acid_dissociation_constant, or else do a google search--there is heaps of information out there!
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
