Need help with factors affecting suspension bridge failures
The Tacoma Narrows Bridge collapsed due to a combination of aerodynamic forces and structural design flaws. Engineers failed to account for wind effects, which caused oscillations that exceeded the bridge's material limits. The bridge's lightweight design contributed to low tension, allowing it to resonate with wind gusts, leading to catastrophic failure. Understanding the principles of tension, compression, and harmonic motion is crucial in analyzing such structural failures.
  • Understanding of tension and compression forces in structures
  • Knowledge of harmonic motion and resonance principles
  • Familiarity with aerodynamic effects on structures
  • Basic physics concepts related to vibrations and material limits
  • Research "Harmonic Motion in Engineering" to understand resonance effects
  • Study "Wind Shear Effects on Bridges" for insights on aerodynamic forces
  • Explore "Torsional Vibrations in Structures" to grasp twisting forces
  • Investigate "Design Principles for Suspension Bridges" to learn about structural integrity
Civil engineers, structural designers, physics students, and anyone interested in understanding the dynamics of bridge failures and the impact of wind on structural integrity.
studenthelp10
ive read articles and it says that the tacoma suspension bridge failed because of its length and it being too thin so when the wind blew on it it fell.
an question i have to answer from school is investigate bridge failures and explain why they failed using physics principles
so exactly how does the blowing of wind on a bridge affect it? does it put more stress on it - so it strains more and then breaks . How does this relate to compression and tension forces?
could you please explain simply
thanks for the reply, i saw the video u posted and it shows the bridge swinging violently from left right? then collapsing, while some of the concrete is held up by the cables. then the bridge getting closed. Because of this I think the bridge must be made of pretty weak material to be pushed by the wind that way.. but i need some solid facts
i did some more research and found this site, but don't understand terminology:
https://docs.google.com/viewer?a=v&...p2NXPL&sig=AHIEtbSJhwG0p6rpl0qLdHP6dCy9fDxewg
looking at the video, what do you think are the tension and compression forces in the bridge?
It's all about harmonics. A steady wind with a velocity that closely matches the natural harmonic length of particular span(determined, largely, by its length and tension) sets up a sympathetic vibration in that span, in much the same way a bottlle produces sound when you blow across its top. This suggests it may be a good idea, among other things, to build bridge spans of unequal length and setting dampers between the spans. All physical objects, including people, possesses their own particular set of harmonics. A loud enough sound tuned to one's primary harmonic could blow one's body apart! The Tacoma bridge event has been shown to all first year physics and engineering students as an example of the power of harmonic amplification of sound waves.
i know from research the tension force is from the cables being pulled apart from the load on the bridge.. and this compresses the towers- but I am unsure how wind comes tp play in this? - a guess would be that the wind is twisting the bridge creating more tension = stress and then strain because the bridges cables cannot handle the stress and cannot stretch in length- so it fails and the cables break? . then when the bridge loses its cables its platform falls? I am not to sure but i thinkk this is what happenned? :) i hope I get this answer its been bugging me all week and i got to finish my assignment soon
thanks for the reply estein :) could you please explain abit more simply? please :)
like does the vibration increase tension or something?
according to definition of sypathetic vibration it is :
sympathetic vibration (plural sympathetic vibrations)
the vibration of a body, at its natural frequency, in response to that of a neighbouring one having that frequency; resonance
i think this means that every object has a limit to vibrating? when u increase the vibrations it breaks apart? solid->liquid?
i hope so to :S
sry guys i new to all of this type of physics and I am struggling to answer this question, so i need simple explanations please :) I really appreciate your replys though :D
I think I've solved it! yay! :D - i was researching and found some good info
i think it says that when the tacoma narrows was designed engineers forgot to take into count other factors like the wind. These added more tension and compression to the cables. when the wind blew the cables tension force was put under greater compression (pushed together) then going back to tension (pulled apart) causing the platform/cement of the the bridge to swing side to side. the movement then broke up the cement and because the material is more rigid/ not very flexible ; it broke apart and the bridge collapsed. :) i will probably use this in my assignment, (correct me if I am wrong) . funny thing i solved my own problem :D
hi studenthelp10! :smile:
(just got up :zzz:)
studenthelp10 said:
… i was researching and found some good info …
stop trawling the internet, and use your own eyes and brain! :rolleyes:
can cables go into compression? :confused:
watch the video
do any of the cables break?
what does break?
what are the internal and external forces on the thing that breaks? :wink:
I need actual facts/ research then I can use my brain to figure out how things go together :S ? and understand it better
none of the cables break but the roadway does. I am not sure what the internal and external forces are sorry? would the external be wind and internal be compression/tension in cement?
the article says :As the diagram above shows, the cables were anchored at each end, and supported in the middle by several raised towers. This allowed for the tension in the cables due to the weight of the cars and road to be conveyed into the ground. The reason the Tacoma Narrows Bridge did not last is that engineers never considered aerodynamics and wind forces, which added both a compression and tension force to the bridge. Every time the wind blew at strong gusts the tension force of the cables would be overcome by compression, then back to tension causing galloping oscillations of the deck or road. It didn’t help that the engineers built the bridge so light either. Without the weight of the bridge to dapper the oscillations they could be very intense. The material holding the deck during these vigorous movements finally tensed to a point of collapse and the bridge went down.
is this wrong?
i may have mis understood this bit "Every time the wind blew at strong gusts the tension force of the cables would be overcome by compression, then back to tension causing galloping oscillations of the deck or road"
after reading it through again i think its probably the road that is getting more compression by the wind causing more tension in the cables then when the wind stops it goes back to normal then starts again... causing the twisting of the road.
probably because the bridge caught more air under neath it (like a parachute) when the wind blew under it. I think this created those compression forces
yes, i think you have to concentrate on the tension and compression of the road
form the video, the chains were perfectly capable of supporting the weight of the road, it was the road itself that was at fault (and of course the chains can swing in any direction, so they're contributing almost no structural stability to the shape of the road)
i don't think a road much minds being in compression, surely it's only tension that's a problem?
as you say, the video shows clearly that the wind is causing the road to twist … perhaps you should consider why it isn't twisting equally all the way along?
If you want to research something look up torsional harmonic motion.
Consider what happens when air hits a surface, and also what happens when it travels over and under it.
Also, was it that the bridge was light that caused a problem? The bridge they erected in it's place after the incident was very nearly a copy except for a glaring detail...trusses...which even potentially made it "lighter"
Lightweight isn't a problem if something is properly designed.
Note: When they say the tension in the cables was overcome by compression, what they mean is that the tension in the cables (usually taut) went to, basically, zero as the bridge sections they were attached to shifted. They word it poorly and, in my opinion, improperly.
The original excitation that started the torsional vibration of the Tacoma Narrows bridge was vortex shedding as wind vortices were shed, first off the top, then the bottom of the bridge deck. This drove the torsional motion that happened to coincide with a torsional natural frequency of the deck and the amplitude grew to the point of catastrophic failure.
Thanks again for the replys :)
I tried to find some thing on torsional harmonic vibrations but all they had was a spring motion? and equations i have never heard of before. But i did find this article explaining a bit about what happens when wind goes across a bridge. I think i need to get more info on how the wind twists the bridge and what forces the twisting makes on it. :)
Wind Shear and Resonance
When wind flows horizontally at right angles to a bridge's length, it splits when it encounters the bridge, flowing over and under it. Wind shear is a change of wind speed with altitude. It produces twisting forces along the length of the bridge. An improperly-designed bridge will resonate, accumulating vibrational energy until it fails.
Vibration and Tension
The more tension a guitar player puts on a string, the faster it vibrates. This effect also applies to bridges. The faster the vibration, the more energy it takes to make it vibrate. A bridge under a large amount of tension will not vibrate in any reasonable wind; its tension is too high. The Tacoma Narrows bridge had a very low weight, 5,700 pounds per linear foot, compared to 30,000 for comparable bridges. Its low weight gave it low tension, which made its vibration frequency low, and a mild breeze would set it into motion.
Sponsored Links
Electronic Calibration
Expert Calibration Services. NATA Accredited Lab - Quick Turn Around
www.HKCalibrations.com.au
Fatigue and Collapse
The Tacoma Narrows bridge did not collapse right away. Engineers observed its vibrating behavior and attempted to correct it, but were not successful. The stresses produced in the swaying bridge fatigued its metal and concrete supports for several months, finally leading to its collapse.
Rebuilding
The bridge was rebuilt ten years later after extensive redesign work and testing with scale models. The new bridge had a heavier and wider structure and hydraulic dampeners to absorb vibrations. It has been in service since 1950 and has had no problems with wind vibrations.
Read more: What Happens to a Bridge When There Is Wind Shear? | eHow.com http://www.ehow.com/info_8594590_happens-bridge-there-wind-shear.html#ixzz1rnsMk9F3
I couldn't find anything on torsional harmonic motion to do with wind - only like sring motions and some equations I've never seen before. but i found this article :) to do with how wind acts on a bridge
Sponsored Links
Rebuilding
So if I am putting this altogether: is it like this?
The tacoma narrows bridge was very light and because of this it had less tension in its cables compared to other bridges. This is because the weight of the bridge pulls down on the cables and gives it tension, but since the tacoma is light -there is less weight pulling down and therefore less tension. The effect of this is that it will take a smaller gust of wind to vibrate the tacoma bridge.
When the wind blew against the bridge, some went under above the roadway of the bridge and some went underneath. If the wind is unequal at the top or bottom it causes the bridge to "twist' (move up and down) . The 'twist ' creates more tension (force pulling something apart) to pull the cement apart. Since cement is better in compression than in tension, and more tension was added it broke apart and failed.
Am i making progress? :)
i don't think the tension in the cables matters, i think the problem is the tension in the roadway
the rest looks ok :smile:
so is the second paragraph all i have to say - is there any way i can improve it ? by using information from other sources i found.
Im not sure if these were all the physics principles involved in the collapse?
Travis Kings post from earlier Noted: "When they say the tension in the cables was overcome by compression, what they mean is that the tension in the cables (usually taut) went to, basically, zero as the bridge sections they were attached to shifted. They word it poorly and, in my opinion, improperly"
So the chain of events was the wind -> rocked the cables -> tension to no tension at all then back (zero) as said above = twist of bridge (b/c weight of bridge is light- b/c little tension in cables as bridge was light)-> bridge twists up and down-> the wind added to the twisty motion by splitting up when it hit the bridge some on top and some underneath making it twist more dangerously-> twisting adds compression and tension force to cement-> cement can handle compression but is very bad at tension so cement brike apart-> roadway collapses into river underneath the bridge. ?
would that be a better explanation to put into my assignment?
i need to find a way to link the chain of events together i.e. this ccaused this->... which caused this which made the bridge fail
I will also add in, learn what concrete and cement are and that they are not interchangeable. Vortex shedding, resonance and insufficient stiffness to the lateral loads were issues. Newer suspension bridges decks are actually designed to produce a net downward force which stabilizes the system. Reading someone else's conclusion is not really you understanding what happened.
thanks scutter bob i took into count what you said and i researched vortex shedding http://www.mecaenterprises.com/vortex_shedding.htm shows a diagram.
What I think is happening is that the wind force blowing from left to right on the diagram and traveling above and below the circle. Then curving back inward and spiralling. I am not sure but i think that the wind is pushing from boths sides i.e. direction right and from the spirals going the opposite way (looking like compression horizontally)- opposite forces pushing object inward. I think this then squeezes the circle together and when the sides are squeezed in the top and bottom of the circle expand (looks like tension) forces pulling object outward in opposite direction to stretch . Maybe this is similar to what happens to a bridge :)?. This was all my own thinking - is it right? just need to confirm :D
the note above wasnt a conclusion - it was a step i didnt understand because they worded it badly- but travis Kings explanation makes it a bit more clearer- I am slowly getting there :)
the chain of events does not start with the cables, the wind doesn't rock the cables, the cables merely respond to what the roadway is doing
the cables, basically, are springs, each one will adjust to whatever load is pulling it down
when a heavy vehicle goes onto the roadway, the roadway changes shape slightly, and the tension in the nearest cables reacts to that
the wind vortices are behaving like heavy vehicles, except that they can also reduce the load
they're a bit like the air pockets (of reduced pressure) that an aircraft sometimes flies through
it isn't left and right, it's up and down alternately, causing the roadway to twist
see this image, showing the vortices rolling off the roadway, alternately above and below, from http://saba.kntu.ac.ir/eecd/Ecourses/instrumentation/projects/reports/Flowmeter/vortex_files/vortex10.gif …
(the word "alternative" should of course be "alternate"! :rolleyes:)
the accompanying text explains … (http://saba.kntu.ac.ir/eecd/Ecourses/instrumentation/projects/reports/Flowmeter/vortex.htm)
On the side of the bluff body where the vortex is being formed, the fluid velocity is higher and the pressure is lower. As the vortex moves downstream, it grows in strength and size, and eventually detaches or sheds itself. This is followed by a vortex's being formed on the other side of the bluff body . The alternating vortices are spaced at equal distances.
The vortex-shedding phenomenon can be observed as wind is shed from a flagpole (which acts as a bluff body); this is what causes the regular rippling one sees in a flag. Vortices are also shed from bridge piers, pilings, offshore drilling platform supports, and tall buildings. The forces caused by the vortex-shedding phenomenon must be taken into account when designing these structures. In a closed piping system, the vortex effect is dissipated within a few pipe diameters downstream of the bluff body and causes no harm.​
ooh so its a bit like on the diagram - the flow of wind hits the surface of the object and runs on top and beneath the object. the high velocity fluid is the wind flow and the high velocity fluid is closest to the object and has high pressure, where as the high velocity fluid further away from the object has low pressure. So this then makes the spirals curving inward because the high pressure is on the inside pushing the wind more inward?- sheds. The alternative vortices /spirals are equally spaced and alternate (move one after the other on each side). This then causes the object to twist up and down, following the same motion as the vortices/spirals.- I thinks that's what the diagram is trying to say... but I am unsure if its correct.
Two questions? you said "it isn't left and right, it's up and down alternately, causing the roadway to twist" does that mean the wind is blowing from underneath the bridge upward- like vertically? If it is , I don't get it because isn't the wind blowing horizontally and hitting the surface of the bridge to make it go up and down? because of the vortices or spirals alternating?
Secondly, the twisting makes the compression and tension forces right? because i read an article showing a spaghetti getting compressed (pushed together) and when it bends there is tension in the centre, because the centre is getting stretched.
that's correct :smile:
(but i don't understand your explanation preceding it …)
no, the horizontal force isn't a problem
only the vertical forces from the "air-pockets" (vortices) matters
if the bridge designer could stop the vortices from forming (by streamlining, as in vehicles),
the problem would disappear
studenthelp10 said:
http://science.howstuffworks.com/engineering/civil/bridge2.htm
has a diagram of a plank under tension and compression at the same time- from bending
yes, if you bend something stiff, it goes into tension on the outside of the bend, and compression on the inside
this does not apply to chains cables ropes etc … they can only be in tension
that's an interesting link ("How Bridges Work" by Robert Lamb and Michael Morrissey, 13 pages) …
on page 11 it deals with resonance, including …
… the wind that day was at just the right speed and hit the bridge at just the right angle to set off the deadly vibration. Continued winds increased the vibrations until the waves grew so large and violent that they broke the bridge apart. The effect is similar to that of a singer shattering a glass with her voice.​
… so you see, it wasn't the strength of the wind that mattered, only the exact speed, just as you only need the exact frequency to shatter something​
The explanation you didnt understand was when i was trying to explain the diagram to you using the technical words in the diagram and fully understand the text underneath you posted earlier about wind shedding. I am trying to understand how the vortices are created after it hits the object - i know it spirals inwards because it travels around but - i need a reason. would the reason be because wind pressure is higher on the inside and lower on the outside so it is pushed in.
basically what i was trying to say was that when the wind hit the object, did it go around the object above and below and because of the high pressure closer to the object it created the spirals/vortices?
It may also be helpful to consider the situation in terms of energy. It takes a certain amount of energy to stretch and break a cable or bend a beam. Forces are rate of energy expended per distance moved. The pieces of the bridge are somewhat elastic so that stretching cables and bending beams stores the energy from the imparted forces but when the force is too great they are pushed beyond their elastic limit and break.
Now consider the bridge as designed. The engineers accounted for the force of gravity via the weight of the bridge and the cars it carries. They also accounted for direct force of the wind. What they did not account for was the accumulation of kinetic energy, due to oscillations of the bridge driven by strong winds.
The wind applies a force, the bridge elastically deforms storing that energy, the deformation changes the wind force and the bridge springs back releasing that stored energy which become the kinetic energy of the moving bridge. If the wind stops now the bridge will oscillate with the energy cycling between kinetic energy of motion and stored energy in the springiness of the cables an beams.
Normally that would dissipate over time but before that can happen the wind adds more force and so adds more energy. As explained, whether the bridge will continue to accumulate energy or not depends on resonances. When the wind is blowing just right the oscillatory turbulence will be in time with the oscillatory motion of the bridge so that the wind adds a bit of energy each cycle. The bridge continues to gain energy rocking farther and harder until the material is pushed beyond its elastic limit and beams bend without springing back and wires stretch without springing back. You then have a bridge outside of the design specs and all the engineers carefully balanced forces are out of balance. Wires snap, beams break, and it all comes crashing down.
You may also find it helpful, to research exactly what the engineers do now since this disaster to prevent similar events. Understanding why bridges since then do not fall down is a good way to get at why that one did.
  • · Replies 43 ·
11K
  • · Replies 29 ·
