Need help with gravitational acceleration SI units
The discussion clarifies the relationship between gravitational acceleration and its SI units, specifically addressing the confusion surrounding the term "Distance Fallen in first second." The key takeaway is that this term should be interpreted as acceleration, which has units of m/s². The equation s(t) = ct², where c represents acceleration, confirms that the dimensions must align for the equation to hold true. Participants emphasized that understanding c as acceleration resolves the discrepancies in unit calculations for displacement, velocity, and acceleration.
  • Understanding of basic physics concepts, particularly kinematics.
  • Familiarity with SI units, specifically meters (m) and seconds (s).
  • Knowledge of dimensional analysis in physics.
  • Ability to interpret equations involving acceleration and motion.
  • Study the principles of kinematics in physics, focusing on equations of motion.
  • Learn about dimensional analysis and its applications in verifying physical equations.
  • Explore the concept of gravitational acceleration and its implications in real-world scenarios.
  • Review video resources from reputable institutions like Caltech that explain motion and acceleration.
Students of physics, educators teaching kinematics, and anyone seeking to deepen their understanding of gravitational acceleration and its mathematical representation.
icandothemath
Please ignore strikeout (not sure why post is doing that)
I just watched a video from Caltech (Video link at bottom of post)
It says:
Displacement = Distance Fallen in first second of time in [m] * Time2
so Time2 has no si unit as it is just a ratio right?
Instant or Average Velocity = 2 * Distance Fallen in first second of time[m] * Initial Time[sec] - Distance Fallen in first second of time[m] * Change in Time[sec]
velocity should have the si unit m/s but I am getting m*s (What am I doing wrong?)
Instant or Average Acceleration = 2 * Distance Fallen in first second of time[m] * (Initial Time[sec] + Change in Time[sec])
units should be m/s2 but I am getting m*s (What am I doing wrong?)
Gravitational Acceleration = 2 * Distance Fallen in first second of time[m]
units should be m/s2 but I am getting m (What am I doing wrong?)
Thanks in advance
It says:
Since this is a 28 minute video, can you tell us the time that this statement appears. The SI unit of time is seconds.
When they talk about this (at around 12:30) mark, they specifically state that in the equation ##s(t)=ct^2##, the constant c is numerically equal to the distance fallen in the first second. It does not mean that the constant is a measure of distance, or that its units are that of distance. It merely means that its magnitude is that of the distance fallen during the first second.
The dimensions of c can be deduced from the equation provided above:
if s(t) (distance) is measured in metres, and
t (time) is measured in seconds,
then the dimension of the constant must be [m/s^2], so that when you write the equation in terms of units, you get:
##m= m/s^2*s^2##
and the left side is equal to the right side.
That is, the constant c is acceleration.
Replace each instance of 'Distance Fallen in first second' with acceleration, and you'll have everything agree - everything apart from
icandothemath said:
Instant or Average Acceleration = 2 * Distance Fallen in first second of time[m] * (Initial Time [sec] + Change in Time [sec]
Which should read ##a(t) = 2c##, as they show in the video. (i.e., you made a mistake there)
Thanks Bandersnatch,
Distance Fallen in first second = acceleration was the key to making everything work.
Displacement in meters = m/s2 * s2
Velocity in meters per second = 2 * m/s2 * s - m/s2 * s
Acceleration in meters per second squared = 2 * m/s2
Gravity in meters per second squared = 2 * m/s2
"Distance Fallen in first second" sounded like m/s (or velocity) at first for me. Like it falls this distance in a second.
How do you come up with acceleration?
It does fall that much in the first second, but first second only. When you have ##s(t)=ct^2##, and you set t=1s, then whatever is on the right hand side will tell you 's(1)', i.e. how much something falls in the first second. Since t=1, the only numerical value of this 'how much' must come from the constant c. But since setting t=1 did not make its units disappear (t^2 is 1 [s^2]), the dimensions of c can not be just metres. In fact, in order for the right hand side ([units of c] times [s^2]) to equal the left hand side ([m]), the dimensions of c must be m/s^2.
Imagine you have an object falling in gravitational field near the surface of Earth, with gravitational acceleration g=10m/s^2 (and c=g/2). The equation ##s(t)=ct^2## tells you that after one second, the object falling under this acceleration will have fallen 5 metres.
The math you posted makes sense if we are really talking about "Velocity in the first second" m/s^2
I think the mess up in my mind is the description of "Distance Fallen in first second"
Should the speaker have said "Velocity in the first second"?
No. Velocity after 1 second is V(1) = 2ct, with t=1s.
Analogous to the distance example, if you substitute t=1s, the V(1) will be numerically equal to 2c. In this case, the speaker would be entirely justified in saying that 2c has a magnitude of velocity after 1 second, even though c is still acceleration.
Dimensional analysis again proves that c is acceleration, since:
left hand side is [m/s]
right hand side is [units of c] times [s)
For both sides to be equal, [units of c] must be [m/s^2]
Thanks for bearing with me, I don't know why this is so hard for me to get my head around. I think it is starting to sink in.
c = Acceleration = the numerical value of Distance Fallen in first second
So, we're really talking about acceleration in that first second.
At one second Distance, Velocity, and Acceleration are all the same numerical value but with different si units.
For example:
change in distance = d2 - d1 = 10m
change in velocity = change in distance / 1s = 10m/s (since initial velocity is 0)
Acceleration = change in velocity / 1s = 10/m/s^2 (since initial velocity is 0)
So, when he says Distance Fallen in the first second the numerical value works.
But we're really talking about Acceleration which makes the si units and numerical values work.
  • · Replies 29 ·
