Solve sin cos: Find cos6x - 4cos4x + 8cos2x =?
  • Thread starter Thread starter johncena
    Cos Sin
The discussion focuses on solving the equation cos6x - 4cos4x + 8cos2x given that sinx + sin2x + sin3x = 1. The solution reveals that the answer is (b) 4, achieved by rewriting the equation and applying trigonometric identities. Additionally, a follow-up question involves finding tan(a + b)cot a given a ratio of sine functions. Participants suggest using specific values for a and b to simplify the problem and derive the answer. The thread highlights collaborative problem-solving in trigonometry.
johncena
Can anyone give any hint to solve this ?
If sinx + sin2x + sin3x = 1,
then , cos6x - 4cos4x + 8cos2x =
(a) 1
(b) 4
(c) 2
(d) 3
Mathematics news on Phys.org
It's probably not in the spirit of the question but you can just solve that cubic numerically and get sin(x) = 0.5437 (to 4 dp). Then using cos^2(x) = 1- sin^2(x) you can easily evaluate it.
BTW. The answer is (b) 4.
Rewrite as: sinx + (sinx)^3 = (cos)^2. Then square both sides and use the identity (sin)^2=1-(cos)^2 and the answer will follow
Thanks for the hint . I got the answer .Now can you help me to solve this ?
If \frac{sin(2a + b)}{sin b} = \frac{n}{m} , then tan (a + b)cot a = ?
(A)\frac{n-m}{n+m} (B) \frac{m-n}{m+n}
(C)\frac{n+m}{n-m} (D)\frac{m+n}{m-n}
I suppose the easiest way would be to choose values for a and b and see which fail.
Write sin(2a+b) as sin [a+(a+b)] and sin(b) as sin[a+(b-a)]. Then use the double angle identities and you should obtain the answer easily.
Thank you very much for your help sir...I got the answer easily
