Need The sum of time to calculate speed
  • Thread starter Thread starter Tumbleweed
    Speed Sum Time
The discussion centers around a physics problem involving a discus in uniform circular motion, where a horizontal force of 280 N is applied to a 2.0 kg discus rotating in a circle with a radius of 1.00 m. The main challenge is calculating the speed of the discus without directly knowing the time. Participants clarify that the net force acting on the discus equals the centripetal force, allowing for the use of the formula F_net = F_centripetal = (Mv^2)/R to solve for speed. There is acknowledgment of the difficulty of the subject, especially in an online learning environment, and encouragement to persist despite initial challenges. The problem is noted to be poorly worded, leading to confusion about the nature of the forces involved. Overall, the conversation emphasizes the importance of understanding physical concepts and the value of perseverance in learning physics.
Tumbleweed
To all
Don't you need The sum of time to calculate speed.
This is the question in my book
A horizontal force of 280 N is exerted on a 2.0 kg discus as it rotated uniformly in a horizontal circle (at arms length) of radius 1.00 m. Calculate the speed of the discus.
I am not he smartest person around but I just for the life of me can not figure how to get the time. am I suppost to assume it.
Thanks
tumbleweed
As far as I can tell, the discus is undergoing uniform circular motion.
F_{net} = F_{centripetal} = \frac{Mv^2}{R}
You know all the values except v for which you need to solve.
speed
Thanks
The same formula is in the book but worded diff
That helped alot
This is my first physics class of many and I can now see it will be along road.
I am taking the class on line and I can see I needed a real class.
Thanks again
Tumbleweed
Yes, physics unlike many other classes will be quite difficult without some guidance to help you "unwire" a lifetime of mostly false intuitions about the workings of the natural world. The only advice I have is to stick with it and you will make it through with a good understanding. I never thought of my self as particularly intelligent either, but through hard work, and really thinking through the implications of the physical laws and methods I've learned, I have succeeded and made it through all my classes with A's. My advice to you for success would be the same.
Don't sweat it, it appears to me to be a poorly worded problem. I also would have guessed the force was a torqure accelerating the disk, not the centripedal force on it.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
