Negative distance? Can it be real?
  • Context: Undergrad
  • Thread starter Thread starter Oldblood
    Negative
The discussion centers on the concept of negative distance in relation to two planes flying towards the same airport from opposite directions. The derived formula for distance is distance = v1v2t/|v1-v2|, which suggests that negative distances can occur when the planes travel in opposite directions. The conversation further explores the implications of negative intervals in the context of relativity, where the invariant interval can be negative, indicating a time-like separation between events. Ultimately, the consensus is that while negative distances can be mathematically defined, they lack physical significance in our universe.
  • Understanding of basic physics concepts, particularly motion and velocity.
  • Familiarity with the principles of relativity, specifically the invariant interval.
  • Knowledge of mathematical expressions involving distance and time.
  • Basic comprehension of coordinate systems, including spherical coordinates.
  • Research the implications of the invariant interval in Einstein's theory of relativity.
  • Explore mathematical models of motion in non-Euclidean geometries.
  • Study the concept of time-like and space-like intervals in physics.
  • Investigate the relationship between velocity, distance, and time in various coordinate systems.
Students of physics, mathematicians, and anyone interested in the theoretical implications of motion and distance in both classical and relativistic contexts.
Oldblood
I started wondering about this after solving a problem on the exam. Here is the problem: 2 planes has a speed v1 and v2. They are flying from the airport at the same time. The difference between their landings on the same airport is t. Express the distance between the airports as functions of v1, v2 and t.
This is what I got: distance= v1v2t/|v1-v2|
If this formula for the distance between the airports allways applies and we have defined positive and negative velocities as oposite directions when the problem is 1 dimensional, we get a negative distance if the planes goes in oposite directions and lands on the same airport after a time t.
So here is my question: May there be such a mystic thing as negative distance so that 2 planes can go in oposite directions and land on the same place after a finite amount of time? Could this be something physical, not observed in our universe, but still real in other strange universes and extremely hard for us to imagine?
No need for weird alternate universes to have the two aircraft heading in opposite directions land in the same airport. If you map the coordinates to a sphere(like the Earth), that's exactly what you'll get.
In relativity, the usual notion of distance is replaced by the invariant interval, which can be negative. The invariant interval between two events is (in +++- convention) the square root of
ds^2=dx^2+dy^2+dz^2-c^2dt^2
This is just the usual notion of distance minus an extra term for the time difference between the two things you are measuring. If you are measuring the interval between two things at the same time, then ds is just the distance. A negative interval means that the interval is time-like, which means it's possible for a signal to travel from one endpoint to the other without going faster than c.
Hey,
You are thinking too hard.
It has no physical significance what so ever
http://www.datasea.info/avatar1.jpgNo need for weird alternate universes to have the two aircraft heading in opposite directions land in the same airport.
