scott_alexsk
- 335
- 0
Hello,
How would you determine the value of such numbers as -3^1.5?
Thanks,
-scott
Thanks,
-scott
As you wrote it, you do not have a square root of a negative number:Integral said:[tex]- 3 ^{ 1.5} = - 3^ {\frac 3 2}[/tex]
Do either the square root or the cube first, either way results in the square root of a negative number. So the solution lies in the imaginary plane.
[tex](-3)^{1.5} = (-3)^{\frac{3}{2}} = \sqrt{-27} = \sqrt{27} \sqrt{-1} = \boxed{3i \sqrt{3}}[/tex]BoTemp said:Have you ever worked with complex numbers before? Define i = (-1)^0.5
-3^1.5 = (3)^1.5 * (-1)^1.5 = 3^1.5 * (-1)^1 * (-1)^0.5 =
[tex]-i3\sqrt{3}[/tex]. By extension of this procedure one can define negative numbers to any power.
A good point!bomba923 said:As you wrote it, you do not have a square root of a negative number:
[tex]-3^{1.5} = -3^{\frac{3}{2}} = - \sqrt{27} = - 3\sqrt{3}[/tex]
On the other hand,
[tex](-3)^{1.5} = (-3)^{\frac{3}{2}} = \sqrt{-27} = 3i \sqrt{3}[/tex]
While "the" square root of a positive real number is define to be the positive root, that is not true for complex numbers, where most functions are "multi-valued". (-3)1.5 has two values,[tex](-3)^{1.5} = (-3)^{\frac{3}{2}} = \sqrt{-27} = \sqrt{27} \sqrt{-1} = \boxed{3i \sqrt{3}}[/tex]
not
[tex]-3i \sqrt{3}[/tex]
?? or even if k is rational: 1.5 is certainly rational! Did you mean*Also, note that:
[tex]\forall x < 0, x^k \notin \mathbb{R} \; \text{ if } \, k \notin \mathbb{Q}[/tex]
Not really ~~HallsofIvy said:You posted this 9 times?! I deleted the other 8.
I see; so the answer is thenHalls of Ivy said:While "the" square root of a positive real number is define to be the positive root, that is not true for complex numbers, where most functions are "multi-valued". (-3)1.5 has two values,
[itex]3i\sqrt{3}[/itex] and [itex]-3i\sqrt{3}[/itex]
I didn't intend to be an 'if and only if' statement...Halls of Ivy said:or even if k is rational: 1.5 is certainly rational!
Not really//Halls of Ivy said:Did you mean [tex]k \notin \mathbb {I}[/tex]?
~That's exactly what I did! (..."nine times"HallsofIvy said:My reader is so messed up it doesn't always show the changes even after "refresh"! Sometimes what I do is make the changes, copy it, then delete the post (clicking "physically remove") and paste into a new post.
