Negative numbers to non-interger powers
  • Level: Undergrad
  • Thread starter Thread starter scott_alexsk
    Negative Numbers
11 replies · 6K views
scott_alexsk
Hello,
How would you determine the value of such numbers as -3^1.5?
Thanks,
-scott
Mathematics news on Phys.org
[tex]- 3 ^{ 1.5} = - 3^ {\frac 3 2}[/tex]
Do either the square root or the cube first, either way results in the square root of a negative number. So the solution lies in the imaginary plane.
Have you ever worked with complex numbers before? Define i = (-1)^0.5
-3^1.5 = (3)^1.5 * (-1)^1.5 = 3^1.5 * (-1)^1 * (-1)^0.5 =
[tex]-i3\sqrt{3}[/tex]. By extension of this procedure one can define negative numbers to any power.
hmm... idk i would just put it in the caculator :D but i do know that a negative number squared by an odd nuber is X i idk if this helps
As you wrote it, you do not have a square root of a negative number:
[tex]-3^{1.5} = -3^{\frac{3}{2}} = - \sqrt{27} = - 3\sqrt{3}[/tex]
On the other hand,
[tex](-3)^{1.5} = (-3)^{\frac{3}{2}} = \sqrt{-27} = 3i \sqrt{3}[/tex]
[tex](-3)^{1.5} = (-3)^{\frac{3}{2}} = \sqrt{-27} = \sqrt{27} \sqrt{-1} = \boxed{3i \sqrt{3}}[/tex]
not
[tex]-3i \sqrt{3}[/tex]
*Also, note that:
[tex]\forall x < 0, x^k \notin \mathbb{R} \; \text{ if } \, k \notin \mathbb{Q}[/tex]
You posted this 9 times?! I deleted the other 8.
On the other hand,
A good point!
not
While "the" square root of a positive real number is define to be the positive root, that is not true for complex numbers, where most functions are "multi-valued". (-3)1.5 has two values,
[itex]3i\sqrt{3}[/itex] and [itex]-3i\sqrt{3}[/itex]
*Also, note that:
?? or even if k is rational: 1.5 is certainly rational! Did you mean
[tex]k \notin \mathbb {I}[/tex]?
Not really ~~
The problem was that I couldn't edit the [tex]\LaTeX[/tex] just by using the "Edit" or "Go Advanced". I had to post, delete, and repost :frown: (for some time, so it "appeared" as though I posted nine times)
I see; so the answer is then
[tex]\pm 3i\sqrt{3}[/tex]
I didn't intend to be an 'if and only if' statement...
Halls of Ivy said:
Did you mean [tex]k \notin \mathbb {I}[/tex]?
Not really//
my statement there wasn't necessarily for scott_alesk's question;
it's just a property I like, that's related to complex numbers (~which this thread involves~).
What I meant to say was that any negative real raised to an irrational power cannot be a real number (the imaginary part of all solutions for [itex]x^k[/itex] is always nonzero if [itex]x<0[/itex] and [itex]k \notin \mathbb{Q}[/itex]).
(However, is this also the case if [itex]k\notin \mathbb{Z}[/itex] ? But doesn't [itex](-1)^{1 / 3}[/itex] have one real solution equal to [itex]-1[/itex] ?)
Sometimes after you've changed the latex by editing and committed the changes, they don't show until you refresh the page.
My reader is so messed up it doesn't always show the changes even after "refresh"! Sometimes what I do is make the changes, copy it, then delete the post (clicking "physically remove") and paste into a new post.
~That's exactly what I did! (..."nine times" :frown:)
I often open the image itself in a new window, and reload that. It's easy to do in opera, but I don't know about the other major browsers.
