How to Calculate Net Electric Force Correctly?
The net electric force on charge A is calculated using Coulomb's Law, represented by the equation F = (K * Q1 * Q2) / r^2. In this discussion, the forces exerted by two other charges (q1=1.1 nC and q2=0.72 nC) on charge A are evaluated, yielding F2on1 = 3.59 x 10^-5 N and F3on1 = 6.486 x 10^-5 N. The net force is determined by summing these forces, resulting in Fnet = 1.01 x 10^-4 N, indicating a positive direction towards the +x axis.
  • Coulomb's Law for electric force calculation
  • Understanding of electric charge units (nC)
  • Vector addition of forces
  • Basic knowledge of electrostatics
  • Study the implications of charge placement on net electric force
  • Learn about electric field concepts and their relation to forces
  • Explore the effects of multiple charges on a single charge
  • Investigate the role of distance in electric force calculations
Students studying electrostatics, physics educators, and anyone seeking to understand the principles of electric forces and charge interactions.
BuBbLeS01
Net Electric Charge...Please help!
What is the net electric force on charge A? (s=1.41 cm, q1=1.1 nC, q2=0.72 nC, q3=5.21 nC. Force is positive if it points to +x direction.)
F = (K * Q * Q) / r^2
F2on1 = (K * Q1 * Q2) / r^2 = 3.59 x 10^-5 N
F3on1 = (K * Q2 * Q3) / 2r^2 = 6.486 x 10^-5 N
F3on1 - F2on1 = 2.9 x 10^-5 N
It's not right...what am I doing wrong?
Your picture isn't working.
Is it working now?
Maybe this is a typing error, but this should be Q1 and Q3.
What are the directions of the forces on Q1? (Remember you are taking the force as positive if it is in the +ve x direction.)
Oh yea that was an error...
F2on1 = right, positive
F3on1 = left, negative
OK, so what is the net force according to this?
to the right, positive because the negative charge is closest to A which exerts a positive force on A
Yes, the negative will draw A towards +ve x, but the other positive charge C will push it away (-ve x direction). You must sum up the forces (they are vectors).
Oh ok so you add them because A is on the end. If it was in the middle you have to subtract them right?
F2on1 + F3on1 = 1.01 x 10^-4 N
F2on1 is drawing A towards B. So the force is positive according to your convention. F3on1 is pushing A away since like charges repel. That force is in the negative direction. So Fnet = F1on2 - F1on3. It is the difference between the forces. The sign of the answer tells you which direction the of net force.
So I do...
(3.59e^-5) - (-6.486e^-5) = 1.01e^-4
10K
