Net Force Exerted by Two Charges on a Third Charge (Coulomb's Law)
The forum discussion centers on calculating the net force exerted by two point charges on a third charge using Coulomb's Law. The charges involved are q1 = -14.5 nC at x1 = -1.745 m, and q2 = 36.5 nC at the origin, with a third charge q3 = 45.5 nC located at x3 = -1.085 m. The user calculated the forces exerted by q1 and q2 on q3 but received incorrect feedback on their answers. The primary issue identified was the incorrect use of charge units, as the charges are given in nanocoulombs (nC) rather than coulombs (C).
  • Coulomb's Law for calculating electrostatic force
  • Understanding of charge units (nC vs. C)
  • Basic algebra for manipulating equations
  • Knowledge of distance measurement in physics
  • Review the conversion of nanocoulombs to coulombs for accurate calculations
  • Practice solving problems using Coulomb's Law with varying charge values
  • Learn about vector addition of forces in electrostatics
  • Explore the concept of electric field strength and its relation to force
Students studying physics, particularly those focusing on electrostatics and Coulomb's Law, as well as educators seeking to clarify common misconceptions in charge calculations.
PHYSteve
This problem has been posted before with different values for each variable and I
did as best I could to complete it similarly. However, when I attempt to input my final
answer I get it wrong every time. I just wanted to see where I am going wrong, thanks.
Coulomb's law for the magnitude of the force F between two particles with charges
Q and Q' separated by a distance d is:
|F| = K(|QQ'|)/d2
Consider two point charges located on the x axis:
one charge, q1 = -14.5nC, is located at x1 = -1.745m
the second charge, q2 = 36.5nC, is located at the origin.
What is the net force exerted by these two charges on a third charge
q3 = 45.5nC, placed between q1 and q2 at x3 = -1.085?
Your answer may be positive or negative, depending on the direction of the force
K = 1/4\pi\epsilon0
I found the distance between q1 and q1 to be 0.660m
I found the distance between q3 and q2 to be 1.085m
I began by finding the charge q1 exerts on q3
by:
|F1| = K*[|(-14.5*45.5)|/(0.6602)] = 1.362E13
(At this point in the problem there is a hint section asking for this force, when I submit the answer I calculated I am told it is wrong.)
And then I found the charge q2 exerts on q3 by:
|F2| = K*[|(45.5*36.5)|/(1.0852)] = 1.268E13
(Again, there is a hint section asking for this value, which also tells me it is wrong)
From those two calculated forces I take F1 - F2 to get a final answer, which is ultimately deemed incorrect.
Any help would be appreciated!
Units! The charges are quoted in nC, not C.
Gah! I knew it would be something small. It always is. Thanks!
10K
