Calc Neutrino Energy Threshold for νe + ^71Ga → ^72Ge + e⁻
In summary, the discussed nuclear reaction involves the interaction between a neutrino and a Gallium-71 nucleus, resulting in the production of a Germanium-71 nucleus and an electron. The energy threshold for this reaction is approximately 0.23 MeV, which can be calculated by finding the Q-value of the reaction. The Q-value is calculated using the nuclear masses of the nuclei involved, rather than the atomic masses, as the electrons do not participate in the reaction.
Nakalay
Hi. I am curious about the following nuclear reaction:
[tex]\nu_{e} + ^{71}_{31}Ga \rightarrow ^{71}_{32}Ge + e^{-}[/tex].
Can anyone explain to me why this reaction has an energy threshold of approximatly 0.23 MeV? How does one calculate the minimum energy of the neutrino for this reaction to take place?
Thanks in advance.
Just calculate the Q-value of the reaction.
Is this homework?
If you do the calculation, you will see that the threshould energy is approx 0.25MeV (depending on how many/good numbers you have from your table, I just did)
If you have no idea what Q-value is, then I suggest you look it up and present your attempt to a solution before we proceed. This is very straightforward and these kinds of reactions are covered in all introductory nuclear physics books.
All right, that was surprisingly easy. I found the energy threshold to be approximatly 0.236 MeV:
[tex]Q = -\Delta m\times c^{2} = (70.924954 u - 70.924701 u)\times931.494 \frac{MeV}{u} \approx 0.236 MeV[/tex]
Thanks for the help.
I think this is wrong.
Tabulated are the ATOMIC masses, i.e all electrons are included.'
Before the reaction you have 31 electrons, and after you have 32 + 1 = 33; so you must remove 2electron masses.
Now i calculate with the nuclear masses.
[tex] M( ^{71}_{31}Ga ) = 70.924701 - 31*0.0005486 = 70.9076944 u [/tex]
[tex] M( ^{71}_{32}Ge ) = 70.924954 - 32*0.0005486 = 70.9073988 u [/tex]
[tex] Q = M( ^{71}_{32}Ge ) + m_e - M( ^{71}_{32}Ge ) = 70.9073988 + 0.0005486 - 70.9076944 = 2.53*10^{-4} u = 0.235667 MeV [/tex]
Might not differ so much in this case, but the principle is imortant. In another reaction than this, it might make big difference.
Great, thanks again. I was actually wondering why I hadn't accounted for the electrons.
I've lost my physics book and I haven't been able to find much information elsewhere on the web so your help is much appreciated.
Too bad you have lost your book! =(
But have you looked at your library? There should be plenty of books about introductory nuclear physics. Remeber that even quite old books from the 1950-1960 is good for this.
I've found my book again so no worries. There is one thing I have not yet fully understood, though. Why is it that you have to use the nuclear masses instead of the atomic masses in the calculation?
Only the nucleus takes part in the reaction. The atomic electrons don't parcipitate.
This is reflected in the Q-value, which is defined for the nucleus mass.
What is the Calc Neutrino Energy Threshold for νe + 71Ga → 72Ge + e⁻?
The Calc Neutrino Energy Threshold for νe + 71Ga → 72Ge + e⁻ is the minimum energy that a neutrino must have in order to interact with a Gallium-71 (71Ga) nucleus and produce a Germanium-72 (72Ge) nucleus and an electron.
Why is the Calc Neutrino Energy Threshold important?
The Calc Neutrino Energy Threshold is important because it helps us understand the properties of neutrinos, which are fundamental particles in the Standard Model of particle physics. It also allows us to study the interactions between neutrinos and other particles, which can provide insights into the nature of the universe.
How is the Calc Neutrino Energy Threshold calculated?
The Calc Neutrino Energy Threshold is calculated using the conservation of energy and momentum laws. It takes into account the masses of the particles involved, as well as their energies and velocities.
What factors can affect the Calc Neutrino Energy Threshold?
The Calc Neutrino Energy Threshold can be affected by the masses of the particles involved, as well as the distance between them. It can also be influenced by the environment in which the interaction takes place, such as the presence of other particles or a magnetic field.
How is the Calc Neutrino Energy Threshold experimentally determined?
The Calc Neutrino Energy Threshold is experimentally determined by conducting experiments that involve the interaction between neutrinos and nuclei, such as the Gallium-71 experiment. By analyzing the data from these experiments, scientists can determine the minimum energy required for the interaction to occur.
  • Cosmology
