Newtonian mechanics and capstan
The discussion centers on the mechanics of a capstan, specifically analyzing the relationship between tensions Ta and Tb when a rope is wound around a circular body. The equation Ta = Tb[exp(-mu theta)] is established, where mu represents the coefficient of friction and theta is the total angle subtended by the rope. Participants reference Kleppner and Kolenkow for clarity on the problem, emphasizing the need to derive equations involving tension and normal force. The derivation involves small angle approximations and the balance of forces acting on the rope.
  • Understanding of Newtonian mechanics
  • Familiarity with tension and friction concepts
  • Knowledge of small angle approximations
  • Ability to interpret mathematical equations in physics
  • Study the derivation of the equation Ta = Tb[exp(-mu theta)] in detail
  • Explore the concepts of tension on a cord wrapped around a rough post
  • Review Kleppner and Kolenkow, specifically problem 2.24
  • Learn about the application of small angle approximations in physics problems
Students of physics, particularly those studying mechanics, engineers working with tension systems, and anyone interested in the practical applications of friction in mechanical systems.
Kolahal Bhattacharya
Consider a capstan.A circular body around which a strong rope is wound.The free ends of the rope are pulled with tension Ta and Tb. Ta>>Tb.Co--eff. of friction is mu.theta is the total angle subtended by the attached portion of the rope on the centre of the drum.Prove that Ta=Tb[exp(-mu theta)]
https://www.physicsforums.com/showthread.php?t=94379
Not only that, but the description is not very clear. Got a drawing?
re Newtonian mechanics
I cannot give the picture here.Pleaase refer to Kleppner and Kolenkow 2.24 for this problem.My calclation gives Ta= Tb+(mu)N, where N has the same value as the centripetal force.according to the answer, N should be equal to (Ta-Ta exp(-mu theta)). I could not get it
You need to derive the following equations:
(T + dT) cos dtheta - T - mu N ds = 0
(T + dT) sin dtheta - N ds = 0 where N is the normal force / unit length
Use the fact that dtheta is small and eliminate N
This is called Tension on a Cord Wrapped around a Rough Post
  • · Replies 32 ·
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 27 ·
