Newton's Method General Formula
7 replies · 4K views
crybllrd
The statement [itex]\sqrt[4]{a}=x[/itex] means that [itex]x^{n}=a[/itex].
Using this, we can approximate the radical [itex]\sqrt[n]{a}[/itex] by approximating the
solution to the equation [itex]x^{n}-a=0[/itex].
Consider the function [itex]f(x)=x^{n}-a[/itex].
We can use Newton's Method to approximate where f(x)=0 and thus approximate the radical
[itex]\sqrt[n]{a}[/itex].
a) Use Newton's Method with the function [itex]f(x)=x^{n}-a[/itex]
to obtain a general formula approximating [itex]\sqrt[4]{a}[/itex].
b) Enter [itex]\sqrt[4]{100}[/itex] using your calculator and give the approximation to the
accuracy found by your calculator.
c) Use the formula found in (a) and make a table of values to approximate
[itex]\sqrt[4]{100}[/itex] to the same accuracy as your calculator. Use 3
as your initial guess.
d) How many iterations are required to obtain this same accuracy?
e)The fundamental theorem of algebra guarantees 4 solutions to x^4-100=0.
you just found one. Are there more real solutions? Use your tools of calculus to sustain
your answer.
[itex]x_{2}=x_{1}-\frac{f(x_{1}}{f'(x_{1}}[/itex]
a)[itex]f(x)=x^{n}-a[/itex]
Am I supposed to assume a is constant here? If so, then:
[itex]f '(x)=nx^{n-1}[/itex]
[itex]x_{2}=x_{1}-\frac{x^{n}-a}{nx^{n-1}}[/itex]
b) Easy enough, plugged it into the calc to get 3.16227766.
c) I want to make sure I have part a) right before making a chart.
d) This will be simple after part c)
e) I can tell I will be stuck on this final part. Any tips to help me get started?
Thanks for the reply.
I'm working on part c). She has a set up a chart like this:
I guess I'm confused as to where I use n=4 and n=iteration
Yes. It's a pity n is used for 2 different things.
Let's just say that the n in your formula needs to be replaced by 4, while all the occurrences of n in your table should have been named k or i.
Oh ok, not sure why my teacher would do that to us :P
However, my numbers are not converging.
My n=1 is 3.175925926
n=2 is 2.986439461
n=3 is 3.191986488
n=4 is 2.970703369
I stopped there because they should be converging to 3.16227766.
Here's what I am using:
f(x)=x^4-100
f '(x)=4x^3
so, [itex]x-\frac{x^{4}-100}{4x^{3}}[/itex], where x is the previous approximation (x1=3)
Am I missing something?
n=2 is 2.986439461
n=3 is 3.191986488
n=4 is 2.970703369
f(x)=x^4-100
f '(x)=4x^3
Not sure what you did, because starting from n=2 I get a different sequence, which is converging.
To make it explicit:
[itex]x_{k+1} = x_k-\frac{{x_k}^{4}-100}{4{x_k}^{3}}[/itex]
and
[itex]3.1759-\frac{3.1759^{4}-100}{4 \cdot 3.1759^{3}} = 3.162[/itex]
Not sure what I did either, but I redid it and got it in 3 iterations.
For the final part, I should have 4 solutions to x^4-100=0,
3.16227766 being one of them, and -3.16227766 would be another.
How would I go about getting the others? I'm assuming they are not real solutions.
Quite right.
The other 2 roots are:
3.16227766 i
and
-3.16227766 i
where i is the imaginary constant, or sqrt(-1).
What they would have intended (I think), is that you can find the negative root from the fact that looking at the graph of y = x^4 - 100, you'll see 2 real solutions. ;)
