- 8,947
- 687
rcgldr said:Cambered air foils can generate lift at zero "geometrical" angle of lift
Yes, but they still produce downwash at those negative angles of attack. On a cambered airfoil, most of the diversion of flow takes place near the peak of the cambered airfoil and the pressure differential decreases with distance aft of the peak. If the trailing edge is shortened somewhat, the diversion still takes place, but now the wing has a negative AOA due to the trailing edge being shortened relative to the leading edge. This is why effective angle of attack is sometimes used to compare the properties of different airfoils (effective AOA being zero at zero lift).DarioC said:airfoils can and do generate lift at negative angles of attack
rcgldr said:As far as downwash goes, forces don't dissipate. ... the force that gravity exerts on the aircraft ... eventually exerts ... back onto the surface of the earth.
Consider the Earth's atmosphere, and any objects "supported" by the atmosphere (aircraft in level fliight, balloon hovering, ...) as a closed system. The average force on the surface of the Earth will correspond to the total weight of the atmosphere and any objects "supported" by the atmosphere.Stan Butchart said:Do you know of a good reference that really explains this.
Reduce this to a very large sealed container. The container weighs 50 lbs, the air inside weighs 49lbs, and there's a model aircraft inside that weighs 1 lb. As long as the center of mass of the system is not accelerating vertically, the weight of the system will be 100 lbs, even when the model aircraft is in level flight (doing circles or figure eights) inside the container. The weight of the air and the model result in a pressure differential within the container, lower near the top, higher near the bottom, and the resultant downforce on the container corresponds to the weight of the air and the model aircraft. The model's affect on the air inside increases the pressure differential so that the downforce increases by the weight of the model. The model increases the pressure differential by inducing downwash as it flies (unless in ground or "ceiling" effect mode).
