No idea on how to start finding inverse Laplace Transform
7 replies · 2K views · last reply
abc617
So my professor is really bad and I've had to try to learn to learn this stuff myself. But I have no idea where to start and where to go.
Problem:
[tex]X(s) = \frac{3(3s+2)}{9s^{2}+12s+4}[/tex]Attempt
All I've been able to figure out so far is:
-> [tex]X(s) = \frac{3}{(3s+2)^{2}} * \frac{1}{(3s+2)}}[/tex]
But after that I'm unsure. The table of Laplace Transforms I have doesn't have anything resembling this form:
[tex]\frac{1}{(as+b)^{2}}[/tex]-=-=-=-=-==-=-=-=-=-=-
On a side note, I still have this other thread [https://www.physicsforums.com/showthread.php?t=465600] that I still am unsure of. Help on this thread would be greatly appreciated
Alright so I tried redoing it and this is what I redid:
-Resimplified the equation
[tex]X(s) \frac{3(3s+2)}{9s^{2}+12s+4} <br /> => \frac{3(3s+2)}{(3s+2)(3s+2)}<br /> => \frac{3}{3s+2}[/tex]
The problem here is that I don't know if there is an inverse transformation for the denominator because there is a coefficient in front of the [tex]s[/tex]. Would I factor out a [tex]3[/tex] and get this:
[tex]\frac{3}{3s+2} => \frac{3}{3} (\frac{1}{s+ \frac{2}{3}})[/tex]
So now you have
X(s)= 1/(s+ 2/3)
Now do you know any laplace transform that looks like this?
Well I have
[tex]\mathcal{L}^{-1}(\frac{1}{s + a}) = e^{-at}[/tex]
So I assume the answer should be:
[tex]x(t) = \mathcal{L}^{-1}(\frac{1}{s+\frac{2}{3}}) = e^{\frac{-2}{3}t}[/tex]?
Problem:
Attempt
No. This doesn't follow from the equation above it.
[tex]\frac{3(3s+2)}{9s^{2}+12s+4} = \frac{3(3s + 2)}{(3s + 2)^2}[/tex]
Now simplify.
EDIT: I see that you corrected this in your later post.
This is better, but your notation is confusing. You should not be using =>
This is what you should have.
[tex]X(s) = \frac{3(3s+2)}{9s^{2}+12s+4} <br /> = \frac{3(3s+2)}{(3s+2)(3s+2)}<br /> = \frac{3}{3s+2}[/tex]
