Non conservative forces: work + coefficient of static friction
The discussion revolves around a physics problem involving a sled moving up and down an incline, incorporating concepts of work, kinetic and potential energy, and friction. The specific focus is on the effects of static and kinetic friction on the sled's motion.
  • Mixed
  • Participants explore the conditions for static friction necessary to prevent the sled from getting stuck, questioning whether to derive an angle or a range for the coefficient of static friction.
  • There is discussion about the appropriate method to calculate the sled's speed upon returning to its starting point, with some participants suggesting the use of energy conservation principles while others consider kinematics.
  • Questions arise regarding the initial velocity when the sled returns down the incline and the treatment of potential energy at the peak of its ascent.
Participants are actively engaging with the problem, providing feedback on each other's reasoning. Some guidance has been offered regarding the conditions for static friction and the calculation of kinetic energy, but there remains a lack of consensus on certain assumptions, particularly concerning potential energy and initial velocities.
There are indications of confusion regarding the treatment of potential energy during the sled's ascent and descent, as well as the initial conditions for calculating kinetic energy. Participants are navigating the implications of non-conservative forces in their calculations.
Return
[SOLVED] Non conservative forces: work + coefficient of static friction
hey guys, I've been having a little trouble with some parts of this problem, hope someone can point me in the right direction
A 20[kg] sled starts up a 30 degrees incline with a speed of 2.4[m/s] the coefficient of kinetic friction is 0.25.
A) How far up the incline does the sled travel?
B) What condition must you put on the static coefficient if the sled is not to get suck at the point determined in part a?
C) If the sled slides back down what is its speed when it returns to its starting point?
Know: m = 20 [kg]
theta = 30 degrees
v (initial) = 2.4 [m/s]
Mu(k) = 0.25
Ok, so I did part A): I found the net work and how far the sled went up the incline.
Part B) threw me off a little bit. By condition I assume I have to find an angle? Or maybe a range for the coefficient?
What I did was carry out tan(theta) = Mu(s) plugged in 30 degrees for theta and got
Mu(s) = .577 and then said that the condition was that M(s) < .577 is that right?
Part C) Here I wasnt sure if I should use kinematics or conservation of energy equations. There's a friction force which is nonconservative, but I'm not sure how to incorporate this. Any help would be appreciated
Good job so far! Don't you want to say Mu(s)>.577? For part c) it starts with some KE. The PE cancels up and down. So you should be able to just subtract the frictional work from the initial KE to get the final KE, right? Frictional work is just frictional force times total distance travelled, also right?
ok, sounds good, but how do I know the initial velocity to plug into my KE(i) equation?
2.4m/sec. Weren't you given that??
Hi Dick,
I think the original answer of [itex]\mu_s < 0.577[/itex] is correct for this problem.
alphysicist said:
Hi Dick,
Oh, right. It's says "not to get stuck", not "stuck". Thanks for the sharp eye, alphysicist!
oh ok, i think what I'm getting confused about is this: the sled goes up the ramp and then it comes down, can you assume the initial veloctiy coming down is 2.4 [m/s]? that was it's initial velocity when it was going up.Also can you also really disregard P.E.? because it goes up the ramp, stops, then starts going down the ramp. At the point it stops doesn't it have PE and not KE?
I was talking about considering the whole trip. Start at 2.4m/s. Go up. Stop. Come back down. In the round trip PE cancels. Guess I didn't make that very clear. You can also do what you suggest. Assume 0 KE at the top, compute the PE and subtract the frictional work to get the final KE.
