(Non-current) conductors in a magnetic field
The discussion revolves around the behavior of a straight piece of wire in the vicinity of an infinitely long wire carrying a constant current, particularly focusing on the induced electromotive force (EMF) and electric potential differences. Participants explore theoretical implications of magnetic fields, electric fields, and charge distributions in this context.
  • One participant questions whether there is a potential difference induced in a wire parallel to a current-carrying wire, suggesting that the induced electric field may not have a curl due to the constant magnetic field.
  • Another participant raises a concern about the theoretical nature of an infinitely long wire and its implications for circuit formation.
  • A participant clarifies that the discussion is theoretical, focusing on uniform magnetic fields and potential differences in finite wires.
  • It is proposed that if the wire moves perpendicularly away from the current, an EMF would be induced, but questions remain about the uniformity of potential across the wire.
  • Some participants discuss the implications of charge distribution and the role of electric fields in counteracting magnetic forces, suggesting that a static charge distribution may lead to zero net EMF.
  • There is a mention of differing definitions of EMF, indicating potential confusion or variability in understanding among participants.
Participants express differing views on the existence of potential differences and the nature of induced currents in isolated wires. The discussion remains unresolved, with multiple competing perspectives on the implications of magnetic fields and charge distributions.
Participants note that assumptions about the strength of electric versus magnetic forces may influence their conclusions about charge distributions and induced EMF. The discussion also highlights the potential for varying definitions of EMF among participants.
farglenargle
A quick question.
Let's say you had an infinitely long wire carrying a constant current, and a straight piece of wire parallel to it a certain distance away. Obviously, the current, being a motion of charges, will generate a magnetic field, with its curl being equal to the electrical permittivity times the charge density.
As well, this magnetic field will induce an electromotive force in the piece of wire.
However, the question I have is this: it's obvious to me that there is an electric potential produced by the current-carrying wire on the piece of wire, but is there a potential DIFFERENCE? I'm fairly sure that the induced electric field won't have a curl--the magnetic field is basically constant--but I'm not sure about the mere presence of an electric field at all.
If the wire is infinitely long, how can if form a circuit? :confused:
I just mean theoretically speaking. "Infinitely long". Long enough that its ends don't distort the magnetic field around the other, shorter wire. Obviously there will be a potential difference applied at the FAR AWAY left end and the FAR AWAY right end. I'm talking purely theory here, in the case of a uniform magnetic field applied to a finite, non-looping wire, by a different, current-carrying wire.
farglenargle said:
A quick question.
Whatever law is there which would lead you to believe " there is an electric potential produced by the current-carrying wire on the piece of wire" ?
You're right--that was my mistake.
But what if the piece of wire was moving perpendicularly away from the current? The magnetic field in the piece of wire would be changing, implying an EMF--right?
And if so, is the potential equal across the entire wire?
a current would be induced if the wire was moving perpendicularly away from the current. and if they were both very long, then the magnetic field is approximately uniform (as we look in the direction of the axis). So the induced current is approximately the same along the wire. In this case, the magnetic field is causing the EMF right? So there is no difference in potential causing the current.
How can a current be generated in the piece of wire (for more than a few moments) if it's not a circuit? A current flowing in a straight, isolated piece of wire implies charges falling out of one end or another, which obviously doesn't actually happen.
To clarify my meaning, this is a diagram of what's happening (I left off the magnetic field lines as they're implied by the current): http://prntscr.com/15imtk
Think back on what you've been taught. Don't you remember something about 'Rate of change of magnetic flux'?
Oh right, I assumed you were talking about a circuit. OK, the charge carriers will 'bunch up' at the ends, due to the magnetic field pushing them that way (and there is nowhere for them to go). But then, because there is a build-up of charge, there will be an electric field created, which will counteract the force on the charges due to the magnetic field, so a static charge distribution will be reached.
Often, the assumption is made that the electric force between charge carriers is so much stronger than the magnetic force, that there is negligible 'bunching up', so that approximately, nothing will happen, and the charges do not move.
So, because it reaches that charge distribution, ΔV ≈ 0 (or = 0, in a perfect situation)?
If del (/ delta) V is zero then there will be uniform charge distribution??
no, when it reaches that charge distribution, ΔV will be just enough to counteract the magnetic force on each of the charge carriers. In other words, the rate of change of the charge distribution eventually ends up being zero, therefore the EMF is zero. The EMF has 2 terms: first term due to the electric field, and second term due to the magnetic field. These two terms exactly cancel out, so there is no more forces on the charges (in the macroscopic sense). Also, In the limit that the magnetic force is much less than the electric force, then ΔV will still be non-zero. But it will be small. (maybe this is what you meant?)
p.s. the word 'EMF' may be defined differently by different people. Maybe the definition I am using here is not the same as the one you are used to. I think that there are several possible definitions, so it is important to know which one you are using.
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 61 ·
