Non-Newtonian Fluids: Understanding Strength for Armor Experiments
  • Thread starter Thread starter tkav1980
    Fluids
Non-Newtonian fluids, particularly shear thickening fluids, are being explored for potential use in body armor experiments, specifically to create a protective layer between steel plates. The discussion highlights the need for alternatives to cornstarch and water mixtures, aiming for materials that offer greater strength. A Polish company's patented soft armor from 2015 is referenced, although it is not commercially available. Participants suggest searching through patents for recipes and formulations of shear thickening fluids to aid in the experiment. The conversation emphasizes the value of patent research in developing innovative armor solutions.
tkav1980
Hello,
It's been some time since I've visited and the nature of my question could cover engineering, physics or chemistry so I'm unsure where exactly to post it. I hope here is ok.
I don't have the education to understand any published research on the topic and I hope someone here can provide a relatively simple answer.
I'm looking for information on non Newtonian fluids and what they could be made from that would have much higher strength than cornstarch and water. The purpose is to perform a bit of an experiment where the fluid would be placed between 2 plates of different steels, one hardned and one softer to find out what capability a dragon scale style body armor made this way would have against various rounds.
I know there was a polish company back in 2015 developing this type of soft armor but the patented compound they developed is not available for sale.
This is for a video I'm shooting to see if something like this would work as well as level 3 and 3A manufactured armor plates and how big/thick it would need to be made to provide the same level of protection.
Thanks.
Do you have a link to a copy of that patent, or other patents in the field?
I don't. I found several articles referencing it.
https://www.popsci.com/poland-develops-bulletproof-liquid-armor/
I'm not sure this is the same thing but google was able to provide this link. it looks similar to what Moratex produced from the information I could find.
https://patents.google.com/patent/US7226878B2/en
https://www.researchgate.net/publication/259899898_SHEAR_THICKENING_FLUIDS_BASED_ON_NANOSIZED_SILICA_SUSPENSIONS_FOR_ADVANCED_BODY_ARMOUR
There's hundreds of videos on homemade body armor and even attempts at using oobleck but I haven't seen anyone attempt it with any other sheer thickening fluids. I thought it would make for an interesting video.
Patents are always a good place to look for the type of information you are looking for. Now that you have one patent, you can search the patents referenced by that patent, and the patents that reference that patent. Several of those patents mention shear thickening fluids in their titles, others in the body of the patent. Read those carefully because they should have recipes for the fluids.
If you have a company name, you can search for patents assigned to that company. I like to use the U.S. Patent Office site for those searches: https://patft.uspto.gov/. It's an excellent site, but you need to be careful because it is a pure Boolean search.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
