Normal derivative in spheroidal coordinate
The discussion focuses on calculating the normal derivative to the surface of an oblate spheroid using spheroidal coordinates. The relationship between spheroidal and Cartesian coordinates is provided, detailing the transformations for x, y, and z. To find the normal derivative, it is suggested to calculate a basis for the tangent space and then take the cross product. This method will yield the necessary derivatives in terms of u, v, and φ. The approach emphasizes the mathematical relationships inherent in spheroidal coordinates.
dexturelab
Hi PhysicsForums,
I am calculating something related to the spheroidal membrane and want to ask you a question.
I consider a oblate spheroid (Oblate spheroidal coordinates can also be considered as a limiting case of ellipsoidal coordinates in which the two largest semi-axes are equal in length.)
In spheroidal coordinate, the relationship to Cartesian coordinates is
x=a\sqrt((1+u^2) (1-v^2))\cos(\phi)
y=a\sqrt((1+u^2) (1-v^2))\sin(\phi)
z=a u v
Now, I want to know how to achieve the normal derivative to the surface of a spheroid, in terms of the derivatives of u, v and \phi.
Thank you very much.
Mathematics news on Phys.org
Just calculate a basis of the tangent space and take the cross product.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
