Normalized equation for particle in a ring
Titan97
Normalized equation for particle in a ring, where V=0 on a ring of radius 'a' and infinite everywhere else.
Replcing x by rθ,
$$-\frac{\hbar^2}{2I}\frac{\partial^2\psi}{\partial\theta^2}=E\psi$$
By guess, I found out that ##Ae^{ik\theta}## is an eigenfunction of the hamiltonian.
To find ##A##, I used:
$$\int_0^{2\pi}|\psi|^2rd\theta=1$$
But in the solution, they used
$$\int_0^{2\pi}|\psi|^2d\theta=1$$So the normalization constants were different. Which one is correct?
Replcing x by rθ,
You are not integrating a function of ##r, \theta## over two dimensions. It's a simple one-dimensional integral for ##\theta##.
the particle moves along a ring. so the elemental length should be rdtheta
You've defined your ##\psi## in terms of ##\theta##. ##|\psi|^2## is the probability density function in terms of ##\theta##, not in terms of ##l## where ##l## is the arc length along the ring.
Normalisation means that the total proability is 1, so the simple integral of ##|\psi(\theta)|^2 d\theta## is required.
If you transformed ##\psi## into a function of arc length, ##l##, then you would integrate ##|\psi(l)|^2 dl##.
To illustrate this, a constant pdf for ##\theta## would be ##p(\theta) = \frac{1}{2 \pi}##, whereas a constant pdf for ##l## would be ##p(l) = \frac{1}{2 \pi a}##
