Normalizing eigenvector with complex entries
The discussion focuses on the normalization of eigenvectors with complex entries, specifically addressing the eigenvector \[\vec{v}=\left(\begin{array}{c}-2+i\\1\end{array}\right)\]. The user initially misapplies the normalization process, leading to an incorrect normalization factor of \(a=\frac{1}{\sqrt{4-4i}}\). Clarification reveals that the correct approach involves calculating the magnitude using the formula for complex numbers, resulting in \(|-2+i|^2 = 5\) and the correct normalization factor being \(\sqrt{6}\). The user expresses gratitude after resolving the confusion regarding the calculations.
R.Harmon
Hi, I'm having a bit of a problem normalizing eigenvectors with complex entries. Currently the eigenvector I'm looking at is \[\vec{v}=<br /> \left(\begin{array}{c}<br /> -2+i\\<br /> 1<br /> \end{array}\right)\]
If the eigenvectors don't have complex elements I can do this, for example if i have \[\vec{v}=<br /> \left(\begin{array}{c}<br /> 3\\<br /> 1<br /> \end{array}\right)\] and I want to normalize I know that this is the same as \[\vec{v}=\left(\begin{array}{c}<br /> 3a\\<br /> 1a<br /> \end{array}\right)\] and (3a)^2+a^2=1 so the normalized eigenvector is \vec{v}=\frac{1}{\sqrt{10}}<br /> \left(\begin{array}{c}<br /> 3\\<br /> 1<br /> \end{array}\right). However with the first eigenvector using the same method I get (a(-2+i))^2+a^2=1 or a=\frac{1}{\sqrt{4-4i}} giving the normalized eigenvector as \vec{v}=\frac{1}{\sqrt{4-4i}}<br /> \left(\begin{array}{c}<br /> -2+i\\<br /> 1<br /> \end{array}\right) where as the solution should be \vec{v}=\frac{1}{\sqrt{6}}<br /> \left(\begin{array}{c}<br /> -2+i\\<br /> 1<br /> \end{array}\right). Could someone please point out where I'm going wrong? Any help is appreciated.
I believe you should just divide by
sqrt( |-2 + i|^2 + |1|^2)
sqrt( 5 + 1) = sqrt(6)
Unless my algebras gone out the window:
(-2+i)^2=(-2+i)(-2+i)=4-4i+(i^2)=3-4i
not 5?
|a + bi|^2 = (a + bi)(a - bi) = a^2 + b^2
or
|z|^2 = zz* (where z* is the complex conjugate)
so
|-2 + i|^2 = 4 + 1 = 5
Likes debjit625
Ahh ok makes sense. Thanks alot, that was bugging me for hours!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
