Normalizing spherical Bessel functions for free particles
3 replies · 2K views
zhaos
I think, to normalize a wavefunction, we integrate over the solid angle ##r^2 dr d\theta d\phi##. Typically we have ## R(r)Y(\theta, \phi) ## as solutions. If ##Y## is properly normalized, then the normalization condition for ##R(r)## ought to be
$$ \int_0^\infty dr r^2 |R(r)|^2 = 1$$
Now I am trying to develop a general normalization condition for the spherical Bessel functions, which are solutions to the free particle in free space, but solved using spherical symmetry. For example the 0th solution is
$$ R(r) = \sin (kr)/r $$
where ## k = \sqrt{2mE/\hbar} ##.
Now if I were to normalize with integration over ## r^2 dr ##, the normalization integral will not converge. Google searching has been unhelpful so far, but I've tended to see just integration over ## dr ##. So I'm conceptually unsure why this would be the case.
The end goal is to have a general normalization factor for the spherical Bessel functions. If I normalize
$$ \int_0^\infty dr | A R_0(r)|^2 = 1 $$
In this case, ## A = \sqrt{2/\pi k} ##.
In fact I found by just doing the normalization for the first few functions, sqrt(2l+1) works as the additional normalization factor.
But the current sticking point is the integration over dr or r^2 dr.
Thanks.
Free particle states aren't normalizable. You can see this pretty quickly in cartesian coordinates (showing one dimension for simplicity):
[tex] \psi_k(x) = Ne^{i k x}[/tex]
where [itex]k[/itex] is a quantum number related to energy [itex]E = \hbar^2 k^2/2m[/itex]. Since [itex]|\psi(x)|^2 = 1[/itex], clearly you can't normalize this state.
Instead, it's conventional to normalize the states as
[tex] \int dx \psi_{k'}^*(x) \psi_{k}(x) = \delta(k - k')[/tex]
with the dirac delta function. Then you can show that [itex]N = 1/\sqrt{2 \pi}[/itex]. This normalization is useful because you can then write down general normalizable states as
[tex] \Psi(x) = \int dk A(k) \psi_k(x)[/tex]
and now the normalization condition on [itex]\Psi[/itex] becomes
[tex] \int dx |\Psi(x)|^2 = \int dk A(k) = 1.[/tex]
So [itex]A(k)[/itex] is a normalized distribution over which [itex]k[/itex]'s contribute to the wave function. So a good choice for normalizing for your spherical problem would be to generalize the delta function normalization above.
I guess i have
|A|^2 \int_0^\infty dr r^2 \psi^*_{0,k'}(r)\psi_{0,k}(r) = \delta(k-k')
and ## \psi_0(r) = \sin(kr)/r = \frac{i}{r}( \exp(ikr) - \exp(-ikr))##, and the r^2 will cancel, and then one does the integral...
Looks good. You'll need to use the integral I used above,
[tex] \int_{-\infty}^{\infty} dx e^{ikx} = 2 \pi \delta(k),[/tex]
and be careful with all of the algebra. A few points: you should actually have [itex]j_{0}(kr) = \sin(kr)/(kr)[/itex], and you're missing some factors for the exponential form for [itex]\sin[/itex].
