Normalizing the wave function of a free particle
8 replies · 20K views · last reply
maethros
Hello!
Can somebody tell me, how it is possible to normalize the wave function of a free particle using the Dirac delta function?
Thanks!
There are two methods that are commonly used:
1. Box normalization. Space is assumed to be contained in an LXLXL box.
After calculating, say, a scattering amplitude, taking the limit L-->\infty
gives a ifntie result if done carefully.
2. Delta function normalization <x|x'>=\delta(x-x')/(2\pi)^{3/2}.
How can i use the 2nd one this in this case? I have the wave function: psi(x) = A*e^ikx + B*e^-ikx with k = sqrt(2mE/h^2).
I think I can take A = 1, but then i don't know how to continue.
normailization is simple.
u have the wavefunction, all u do is square it and integrate, setting equal to 1
so in ur case, int[-inf to inf] A*e^ikx=A^2*e^2ikx=1
pull A^2 from the integral to get A^2 int[-inf to inf]e^2*ikxdx=1 for the first
1/A^2
1/A^2
Thx, but I know how normalization normally works :rolleyes:
But not in this case: Free Particle and I HAVE TO use the DELTA FUNCTION.
Okay, so let me ask you what [tex]\int_{-\infty}^{\infty} dx e^{\imath (k - k') x}[/tex] is. Once you figure that one out, I think you could probably normalize the wave function pretty well.
What are you going to do with the wave function. If you are going to calculate reflection and transmission coefficients, you odn't have to normalize it.
I only want to know how I can normalize it using the Dirac delta function. That is all.
I never said that i want to calculate the reflection or transmission coefficient.
Your \int |psi|^2 will have four terms. Four each term use
\int exp{ikx-ik'x}=(2pi)^3\delta(k-k').
