Not sure what I can make into equivalent resistors
The discussion revolves around the concept of combining resistors to form equivalent resistors in the context of circuits that also include capacitors. Participants explore the conditions under which resistors can be combined in parallel and the implications of capacitor placement on these combinations.
  • Some participants propose that two resistors can be combined in parallel to create an equivalent resistor, which can then be used in series with a capacitor.
  • Others clarify that for resistors to be considered in parallel, they must be connected at both ends to each other, and the presence of a capacitor can affect this configuration.
  • A participant provides an example illustrating how two 10-ohm resistors can be equivalent to a single 5-ohm resistor when connected correctly, while also explaining scenarios where they would not be equivalent due to different connections.
  • Some participants express uncertainty about whether their circuit configuration allows for the resistors to be considered directly connected, given the presence of a capacitor.
  • A later reply discusses how the equivalent resistance of the circuit can depend on the frequency of operation, indicating that different conditions (like DC or high frequency) will yield different equivalent resistances.
Participants do not reach a consensus on the conditions under which the resistors can be combined, as there are competing views regarding the impact of the capacitor's placement and the definition of "directly connected." The discussion remains unresolved regarding the specific configurations that allow for equivalent resistance calculations.
Limitations include the dependence on circuit configurations and the frequency of operation, which affect the equivalent resistance calculations. The discussion also highlights the need for clarity in definitions and assumptions regarding resistor connections.
egio
Could I combine the two resistors together in parallel to make an equivalent resistor, and then use that equivalent resistor in series with the capacitor?
It would be great if there was some rule of thumb that I can use to know what I can make into an equivalent resistor/capacitor down the line once I come across different circuit combinations.
Thanks so much!
egio said:
Here is the circuit!
Thanks so much!
If I understand your questions correctly, the answer is yes to all of them.
Here is a link about calculating the resistance of a resistors wired in parallel:http://www.electronics-tutorials.ws/resistor/res_4.html
Ah, I see. So to confirm, I can make an equivalent resistor even though the capacitor is there?
And thanks for the link!
Yes, as long as the resistors are connected to each other directly.
Hmm.. Can you please clarify what you mean by "directly?"
In order for the resistors to be in parallel, the resistors need to be connected at both ends to the opposite ends of the other resistor(s).
For example, if I have:
* a 10-ohm resistor tied to nodes A and B;
* another 10-ohm resistor tied to nodes A and B; and
* a capacitor tied across nodes A and C (or node A and B).
then those two 10-ohm resistors are equivalent to a single 5-ohm resistor. The same as this:
* a 5-ohm resistor tied to nodes A and B; and
On the other hand, if you have this:
* a 10-ohm resistor tied to nodes A and C; and
* a capacitor tied across nodes B and C
then these resistors are not in parallel and, unless nodes B and C are connected, are not equivalent to 5-ohm (or any other value) resistor.
Ah, I see. Thank you for the detailss!
davenn said:
Are you saying that that is what resistors that are connected directly look like? Because then looking at my circuit, the resistors are not connected directly, since the capacitor is in between the upper node that they share. Is my intuition correct?
yes, I am saying my pic is what you should have ... anything else is incorrect for what you described in your OP as what you wanted
your image shows that the resistors are NOT in parallel so isn't in line with what you wanted
Dave
Dave
Oohh I see... If I wanted to find the resistance of the entire circuit, how would I since I can't combine them into an equivalent resistor?
way back in post #2, Scott gave you a link to show you how to calculate parallel resistors
you can only measure the combined parallel resistance across the ends of the resistors not from the far side of the capacitor
as it will make the resistance look like an open circuit
The Equivalent single resistance in the first diagram will depend upon the value of the C and the operating frequency. Taking two extremes: for DC or very low frequencies, the equivalent resistance is the value of the right hand resistor (the C isolates the left hand R completely) and for very high frequencies (where the C behaves like a short circuit), the equivalent resistor is the same as for the two resistors connected in parallel.
For frequencies in between (i.e. one a large range) you need to consider the Impedance of all three circuit elements.
  • · Replies 16 ·
  • · Replies 21 ·
17K
  • · Replies 17 ·
