I Why does the author use the notation ##f_c(d)## instead of ##f(c,d)##?
  • I
  • Thread starter Thread starter member 587159
    Addition Notation
The discussion centers on the notation used in a proof regarding a unique binary operation on natural numbers, specifically the choice of ##f_c(d)## over ##f(c,d)##. The author employs this notation to treat ##c## as a constant parameter while varying ##d##, aligning with the earlier definition of ##f_p##. This approach allows for clearer communication of properties related to the function without explicitly referencing the argument. The use of subscripts, as seen in other mathematical contexts, is justified as it maintains a one-dimensional domain while accommodating multiple parameters. Ultimately, the notation serves its purpose effectively within the proof's framework.
member 587159
Hello everyone. I have read a proof but I have a question concerning the notation. To give some context, I will write down this proof as written in the book.
Theorem: There is a unique binary operation ##+: \mathbb{N} \times \mathbb{N} \rightarrow \mathbb{N}## that satisfies the following two properties for all ##n,m \in \mathbb{N}##
1) n + 1 = s(n)
2) n + s(m) = s(n + m)
(s is the successor function as described in the Peano Postulates)
Proof: Uniqueness: I'm going to skip this here as it is bot important for my question.
Existence:
For ##p \in \mathbb{N}##, we can apply the recursiob theorem to the set ##\mathbb{N}##, the element ##s(p) \in \mathbb{N}## and the function ##s: \mathbb{N} \rightarrow \mathbb{N}## to deduce that there is a unique function ##f_p: \mathbb{N} \rightarrow \mathbb{N}## such that ##f_p(1) = s(p)## and ##f_p \circ s = s \circ f_p##. Let ##+: \mathbb{N} \times \mathbb{N} \rightarrow \mathbb{N}## be defined by ##c + d = f_c(d)## for all ##(c,d) \in \mathbb{N} \times \mathbb{N}##. Let ##n,m \in \mathbb{N}##. Then ##n + 1 = f_n(1) = s(n)##, which is part 1) and ##n + s(m) = f_n(s(m)) = s(f_n(m)) = s(n + m)##, which is part 2).
Now, here comes this silly question. Why does the author use the notation ##f_c(d)##? It seems that he's 'hiding' that ##f_c## depends on 2 variables ##c,d## instead of 1. Although I do understand the proof, I feel uncomfortable with this notation.
Thanks in advance
Mathematics news on Phys.org
He wants to consider c as an identifying parameter while d is the variable, in order to be consistent with the definition earlier of ##f_p## ... ##f_c## satisfies the same definition with ##p=c##.
It can be valid to use f(p,d) instead, with the modified notation in the defnition.
Consider the analogous situation:
##f(x)=\sum_{n=0}^N a_ng_n(x)## vs ##f(x)=\sum_{n=0}^N a(n)g(n,x)## ...
Likes member 587159
Thanks. But if I would write ##f(p,d)## instead, this would indicate that ##f## has as domain ##\mathbb{N} \times \mathbb{N}## where the domain is in fact ##\mathbb{N}##, wouldn't it?
Well, by that argument, ##g_n(x)##, in the analogy, has domain ##\mathbb N \times \mathbb R## right?
Are you unhappy with the subscript notation there too?
Consider the set of polynomials ... if y is a polynomial of degree in in x, then we can write ##y = p_n(x)## right?
But p still maps one dimension onto one dimension even though I need another number to specify the degree.
An example in physics would be the single atomic state wavefunction, which would be: ##\Psi_{nlms}(x,y,z,t)## ... so now we have 8 variables, four of them are subscripts specifying the state and four are arguments. What do we gain from writing ##\Psi(n,l,m,s,x,y,z,t)##?
An advantage of using the subscript notation over including it as an argument of the function is that you can talk about ##g_n## (etc) as a particular function, and discussing properties of, without referring to the argument explicitly. This is, in fact, what the author does.
Perhaps it would help to think of ##f_p(s)## as holding the value of p constant and varying s - but, at the same time, recognising the c may take more than that one value in general. This is an implication that notation ##f(p,s)## does not provide. Note: if p is a parameter rather than an argument, then the domain is still 1D.
The author's use is proper and reasonable and consistent and to the purpose of the proof.
What is the problem?
I did not cover the thing with the sums, yet, but your explanation here helped a lot and now I understand it. I just ended high school and I am not familiar with such notations so most likely that's where the confusion started. Once I will start at the university, I will get used to it. Now, there is not a problem anymore. Thank you for helping me out.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
