Number of Images Formed from Reflection & Refraction
  • Thread starter Thread starter Hydrous Caperilla
    Images Optics
The problem involves a glass slab with a refractive index of 2, featuring a left spherical surface and a right plane surface. An object is placed at a specific distance, and participants are tasked with determining the number of images formed through reflection and refraction.
  • Exploratory, Assumption checking
  • The original poster considers three cases of image formation: direct refraction from the left surface, reflection from the right surface, and a combination of refraction and reflection. Some participants discuss the visibility of the third case and the potential for additional reflections affecting image clarity.
Participants are engaging in a back-and-forth about the correctness of the original poster's reasoning. There is acknowledgment of the complexity of the geometry involved, and while some suggest that the original attempt is valid, others propose that the conclusion of "two images" may not be entirely incorrect.
There is an implied challenge in visualizing the scenarios due to the geometry of the setup, and participants are navigating the constraints of the problem options provided.
Hydrous Caperilla
[/B]
A glass slab of refractive index n=2 has left spherical of radius 10cm and right surface plane.From both surfaces refraction as well as reflection takes place.A point of object P is placed at a distance 15cm from point O1.
Mark the correct option
(A)two images are seen by observed E1
(B)Only one image is seen by observer E2
(C)No images are seen by observed E1
(D)No images are seen by observed E2
[/B]
None
I could think of three cases
(1 ) First the object P will get refracted directly from the left spherical surface .Image no 1
(2) The object P will get reflected from the right surface plane.Image no 2
(3) The object P will get refracted from left spherical surface and then normal plane.Image no 3
So I am getting 3 images which is not in the option.Can anybody tell me what is my mistake
With the geometry you'll have a hard time seeing (3), but yes, in principle it should be there. You can continue that with more reflections, but the intensity will drop quickly and the image will get more and more distorted.
So is my attempt correct
Yes, but I think "two images" is not too wrong as answer.
  • · Replies 16 ·
  • · Replies 18 ·
